PFP Posted July 28, 2005 Share Posted July 28, 2005 Installed new tires yesterday and after the rear wheel was removed found rust in the area where the rear wheel bolts to the drive unit. Is this common or something to be concerned about? Thanks for your valued replies. Phil 04 RT Link to comment
Ken H. Posted July 28, 2005 Share Posted July 28, 2005 TADT. The hub is steel and some surface rust is normal. Link to comment
flatbutt Posted July 29, 2005 Share Posted July 29, 2005 I had that issue on my S. I installed a hub plug and that seems to have solved it. Link to comment
jm1515 Posted July 29, 2005 Share Posted July 29, 2005 I read about this 'hub cap' issue soon after I got my 04Rr. FWIW, I went to Lowe's and bought a chromed metal 1 1/4" hole plug made by Hillman. They're in the fastener section. Pops right on, looks good (to me ) and was 1.49 IIRC.... Link to comment
Haynes Posted July 29, 2005 Share Posted July 29, 2005 You should remove the rear wheel and carefully clean the rust from the hub and the wheelstud threads. If you use a small wire brush or other abrasive, be careful not to touch the lip of the hub seal. When the rust is cleaned off, apply a smear of silicon grease to the hub surface. I'd avoid using anything like WD40 in case it has a reaction with the hub seal material. As suggested by others, get yourself a 32mm (1-1/4") sealing plug for the hole. Link to comment
flatbutt Posted July 30, 2005 Share Posted July 30, 2005 As suggested by others, get yourself a 32mm (1-1/4") sealing plug for the hole. Are your plugs no longer available Keith? I've had one for two years now and it is truly a fine piece. Link to comment
Paul Mihalka Posted July 30, 2005 Share Posted July 30, 2005 I think Keith Haynes stopped having the wheel center plugs. I think I got one of his last ones. Too bad... Link to comment
