madness522 Posted July 25, 2005 Share Posted July 25, 2005 I'm coming up quickly on the 6K service and want to do it myself. I was wondering what to use to check the valve clearances. Would any tappet gauge work or is there something more specific I would need to use for an RT? Thanks Link to comment
Rottweiler Posted July 25, 2005 Share Posted July 25, 2005 Any old guage will work, but here's the catch, you will need 2 blades for the exhaust and 2 blades for the intake to be used all at the same time. You can buy expensive separate feelers with fancy rubber coated handles or you can buy 2 sets of cheapo feeler guages and remove the blades that you need, which works just as well for much less $$$. Tie the 2 sets of blades to strings attached to 2 aligator clips, which clip to a head fin. This will keep you from dropping them on the dirty garage floor. Check out the FAQ for excellent how-to's. Link to comment
BigArn Posted July 25, 2005 Share Posted July 25, 2005 But the feeler guages from a BMW dealer like Bob's BMW. You can mail order them and have them in the mail in a couple of days. You will not be sorry. The plastic handles make them easy to handle and gives you a place to tie on some wire or string to help keep them in place. Link to comment
Ken H. Posted July 25, 2005 Share Posted July 25, 2005 Search this board for "OVFD" Somewhere around here there is a link to the old standby step-by-step document. Link to comment
John_Bennett Posted July 26, 2005 Share Posted July 26, 2005 Two gages would be ideal, but I just use one. I have the gages you buy at Sears. The "go, no-go" method mentioned in the How-to's works best for me. Previously I used the "drag feel" method. The last two times I used the "no go" method and now run mine a little tighter as a result. My "feel" wasn't as good as my ego led me to believe. Link to comment
madness522 Posted July 26, 2005 Author Share Posted July 26, 2005 Great info! Thanks to you all! Link to comment
