GA1150RT Posted July 22, 2005 Share Posted July 22, 2005 I know there are probably past links. Where can you buy the RT-P fans and can any dealer install easily with a simple switch instead of a thermostat? Link to comment
BUSTED Posted July 25, 2005 Share Posted July 25, 2005 Hello GA! I mounted RTP fan on my 96 and current RT. I used a rocker switch both times with excellent results. Chicago BMW most likely will have the best price and you could mount it yourself. Not hard to do. Link to comment
Tschamp Posted July 25, 2005 Share Posted July 25, 2005 Anyone have a diagram or picture of how these mount, or can someone tell me if the electrical connections are easy to get at? I'm not sure that mine is running. Link to comment
Ken H. Posted July 25, 2005 Share Posted July 25, 2005 The RTPs have a temp sensor in the oil line that turns on the fan. It rarely does so because the fan rarely is needed. If you want manual control of the fan parallel a dash mounted (or wherever) switch with that sensor. I see you're in KC also. PM me if you need some help doing this. I live in southern Overland Park. Link to comment
GA1150RT Posted July 25, 2005 Author Share Posted July 25, 2005 Thanks for the info. I've heard Chicago BMW has good pricing! Link to comment
Francis Posted July 25, 2005 Share Posted July 25, 2005 Latest issue of BMWOA ON magazine had an article on an inline sensor that automaticall turns the fan on. A dealership had come up with this fix. Link to comment
