Willie Posted July 19, 2005 Share Posted July 19, 2005 Which one is for use in the 1150? I was told to use the 4417 by someone and did so. Still have a about the same feel as the NGK's, but I saw in the FAQ that the 1100's should be using the 4418. (Seems to be hardly any info for the 1150's) Also what Autolite plug can I use in the 1150? Thanks, Terry BTW, I pulled my pink CCP and the bike ran better, but I am still leary about this procedure. I was also having a problem with very rough starts without the CCP in. It would take a few tries to fire the bike. Anyone else have any problem upon startup without using a CCP in the bike? Thanks, Terry Link to comment
Ken H. Posted July 19, 2005 Share Posted July 19, 2005 Yes, one step colder for the 1150 - 4417. Link to comment
Rich06FJR1300 Posted July 20, 2005 Share Posted July 20, 2005 actually i used the autolite's 3923's for the 1150. Seemed to run better than the bosch's at idle. Link to comment
Flash1034 Posted July 20, 2005 Share Posted July 20, 2005 What plugs are you guys using on the 04 twin plugs? Flash Link to comment
Argon Posted July 20, 2005 Share Posted July 20, 2005 I pulled the pink CCP on my 03 RT about a year ago and did not notice any difference in starting. The only thing I have noticed is that the idle is down around 950 rpm (reading on the tach) and I can't adjust it any higher. The shop I go to said they all read a little low on the tach, but their instruments say it is idling within specs. Other than the idle speed, and I don't know if that is even related to the CCP, I can't say I have noticed the bike starting any differently than when the CCP was installed. Andy Link to comment
Softtail Posted July 21, 2005 Share Posted July 21, 2005 I have been running Bosch 4417 in my 2002 R1150RT for about a year with no ill effect. I can't really notice any change from stock plugs. I put them in to help with a pinging issue, didn't help! I have removed them several times and they are a nice tan color with no shiny stuff on the electrode. Anyway, I just had my 24000 at Mac's Cycle in Lewiston ID and I handed the mech a new set of 4417s. He looked at them and didn't say ZIP, so I assume he didn't see a problem with them? Anyway, I will continue to use them. Link to comment
