SteveSardone Posted July 31, 2008 Share Posted July 31, 2008 my son's ktm 520 dirtbike has a stripped oil drain plug. I've been advised to use a timesert. Any comments by anyone who has used them or something similar? thanks for your help Steve Link to comment
elkroeger Posted August 8, 2008 Share Posted August 8, 2008 Not knowing anything about the KTM, or timeserts, a simple oil drain plug could be swapped for a larger diameter plug, and the hole re-threaded to fit. Just a thought. Link to comment
JMR Posted August 9, 2008 Share Posted August 9, 2008 Look at Helicoil, I've used with success on stripped threads... it has oil plugs on the list of applications printed on the package. You'll have to be careful of any shavings. Link to comment
SteveSardone Posted August 11, 2008 Author Share Posted August 11, 2008 thanks for the suggestions. It looks like I'm going to have to pull the engine to gain the access I need to do the repair. There is a frame member blocking the access I would need to get any kind of drill or tapping tool at the proper angle. After all that work I will use an insert of some kind(helicoil, timesert) with a new plug. Thanks again Link to comment
g_frey Posted August 19, 2008 Share Posted August 19, 2008 It is possible, sometimes, to buy oversize, self-threading replacement plugs. Lots of luck finding them. Link to comment
SteveSardone Posted August 29, 2008 Author Share Posted August 29, 2008 FYI, I took most of the bike apart to get at the engine. I used a time sert kit that I purchased locally. It came with the drill, shoulder cutter, and tap. Used all three on the end of my ratchet. Screwed in the solid insert with the furnished driver and was done. No leaks and everything is good. thanks for your suggestions. Link to comment
