ybweb1 Posted July 1, 2005 Share Posted July 1, 2005 Here it is, the Nav II Plus, with 2GB internal memory. It was a cinch to install. Works great! As you can see the R1200RT tankbag is not in the way. The secret power connection is under the instruments. This shows the white connector from the GPS that plugs into the black socket that is tied to a support strut. Link to comment
DickCW Posted July 1, 2005 Share Posted July 1, 2005 I have this set up on my bike but with a low seat on the low setting, I do need to stretch to see all of the display. If I had the tank bag extended, I would not see anything I fear! I obviously need a leg-extension kit and a proper high seat! Link to comment
fnyrt Posted July 1, 2005 Share Posted July 1, 2005 is that gps power lead hot all the time? or switched with the key? or switched with the power outlet (ie off 30-60 seconds after bike turned off)? thx Link to comment
DickCW Posted July 1, 2005 Share Posted July 1, 2005 My GPS powers down shortly after the ignition is turned off. Link to comment
graemer57 Posted July 1, 2005 Share Posted July 1, 2005 If you find that you are having to look down too much to see your BMW Nav II consider the mount from motorrad concepts. It fits over the clocks. The standard BMW power cables are long enough to use and the GPS unit then is in your line of sight. I've used this solution on my R12RT and it works very well. Link to comment
ape ears Posted July 1, 2005 Share Posted July 1, 2005 Does anyone use the audio output from the BMW Navigator or 2610? The standard Autocom lead will reach from the BMW mount to a tail mounted Pro7,but will it reach from the dash Motorrad Concept mount? Link to comment
Mikus36 Posted July 2, 2005 Share Posted July 2, 2005 What has to be removed to get to the plug ? Is this in front of the battery, or am I looking too hard ? Link to comment
ybweb1 Posted July 2, 2005 Author Share Posted July 2, 2005 What has to be removed to get to the plug ? Is this in front of the battery, or am I looking too hard ? Look at the picture. It is over the front tire between the forks. The connector is wire-wrapped to a center strut under the instrument panel, nowhere near the battery. You must remove the black cover from the black connector. Then, the white plug that comes with the Nav II Plus is inserted into the black socket as the picture shows. Link to comment
bluedl1000 Posted July 3, 2005 Share Posted July 3, 2005 I am new to this site, and am picking up my new R1200RT on Saturday. I would like a GPS system, but am torn between the Garmin, BMW Nav II, and the soon to be released TOM TOM RIDER. How do you like the BMW system? I understand that it is not blocked by the tank bag (which I have ordered), but does the GPS block the bike's information display (I am only 5'9" tall)? How much did the BMW Nav II cost? Thanks for your help! Link to comment
smiller Posted July 3, 2005 Share Posted July 3, 2005 I am new to this site, and am picking up my new R1200RT on Saturday. I would like a GPS system, but am torn between the Garmin, BMW Nav II, and the soon to be released TOM TOM RIDER. http://bmwsporttouring.com/ubbthreads/sh...&PHPSESSID= Link to comment
Highway41 Posted July 6, 2005 Share Posted July 6, 2005 Thanks for the pic; it helped me understand answers to another post which started with curiosity regards what turned out to be the temp sensor. What is the mounting you have over your dash? Saw the power lead going up in the pic. Link to comment
ybweb1 Posted July 7, 2005 Author Share Posted July 7, 2005 What is the mounting you have over your dash? The shelf is from my R1150RT by RCU Designs. My friend RoyB fashioned new brackets. I hear that there is now a R1200RT version from RCU Designs. Mounted on the shelf is a satellite radio and antenna. Link to comment
