CoarsegoldKid Posted June 28, 2008 Share Posted June 28, 2008 I'm needing information/ your experience on drilling into concrete. I'm mounting a tire changer and the instructions say use 3/4 masonry bit and a 3/4 lag shield. I've tried to drill 3/4 holes into concrete before using my 18 volt 3/8 drive and although I did get a hole it wasn't pretty. I tried one hole with the 3/4 and it just destroyed the bit. Next I used pilot holes working up to 3/4. But when it came to the 3/4(new) bit I was only able to do little better. In fact some of the holes wouldn't go deep enough and the two 3/4 bits I used were destroyed. Is there a better way? Link to comment
Firefight911 Posted June 28, 2008 Share Posted June 28, 2008 You need a mason bit and a hammer drill. It is amazing the difference you will see as soon as you go at it with the hammer drill!!!!! Link to comment
mrduck Posted June 28, 2008 Share Posted June 28, 2008 Your cordless drill is not gonna work on something that big. Try the rental yard for a hammer drill, get a new bit, and don't force the bit with a lotta pressure! Let the drill do the work or you'll just melt the end off the bit. Cheap advice from someone who does this alot! Hi joe Link to comment
LandonBlueRT Posted June 28, 2008 Share Posted June 28, 2008 Your cordless drill is not gonna work on something that big. Try the rental yard for a hammer drill, get a new bit, and don't force the bit with a lotta pressure! Let the drill do the work or you'll just melt the end off the bit. Cheap advice from someone who does this alot! +1, from another with experience. Link to comment
ESokoloff Posted June 28, 2008 Share Posted June 28, 2008 I'm needing information/ your experience on drilling into concrete. I'm mounting a tire changer and the instructions say use 3/4 masonry bit and a 3/4 lag shield. (snip) Is there a better way? To start with, I recommend using a 3/8" Drop-in-Anchor. That way the drill size is only 1/2" & 4 of them should be plenty strong enough for the task as I'm sure that drop ins are stronger then lags. This is what I did for the base of my NoMar. I had to use oversized washers on the 3/8" bolts though. Perhaps you could make a non hammer type drill work but an impact type drill is the proper way to do it. Link to comment
fatboyjim Posted June 28, 2008 Share Posted June 28, 2008 Use This - Problem Solved Yup, and I'd use a polyester Resin fix on thread studs too. Pluside is once it cures it becomes part of the floor. Downside is once its cures it becomes part of the floor. Link to comment
mickey05 Posted June 28, 2008 Share Posted June 28, 2008 +1 on the drop in anchors. Shields will loosen up after time. Link to comment
Calvin (no socks) Posted June 28, 2008 Share Posted June 28, 2008 I have installed 6 auto lifts at the dealership. I went to a pawn shop and purchased a hammer drill and several bits for $40.00. I used it and then sold it back to the pawn shop 2 weeks later... Or you could rent one.. Link to comment
Foot Posted June 28, 2008 Share Posted June 28, 2008 Try to find some that carries a chemical anchor in your neck of the woods. they won't loosen up over time and won't stress the concrete the way standard anchors do. Alan Link to comment
CoarsegoldKid Posted June 28, 2008 Author Share Posted June 28, 2008 Thanks guys. What I ended up doing is renting a 1/2" drive Milwaukee hammer drill. I bought a 3/4" bit made for concrete and hammer drill use. I used pilot holes to make sure I was at least centered on each hole. A friend poured water at the hole to cool off the bit. I was able to get three holes out of four and it was a very difficult task. Not easy. I thought I was drilling rebar. The holes were not uniform but the tire changer will stay put. Link to comment
AviP Posted June 28, 2008 Share Posted June 28, 2008 +1 on the hammer drill. Skip the cordless version. BTDT. Link to comment
bakerzdosen Posted June 29, 2008 Share Posted June 29, 2008 Well, I read a thread that (I think David started) talked about the topic a while ago. I decided to just give it a go with my Dewalt 18v cordless drill (with a hammer drill setting - which made a little bit of difference). Suffice it to say, it worked. I did one hole a night, dropped in the anchors, and everything was fine. HOWEVER, it took a LONG time to drill through. YMMV. Link to comment
Twisties Posted June 29, 2008 Share Posted June 29, 2008 Yeah, well I've done ordinary drill w/ masonry bit, hammer drill w/ masonry bit, cold chisel and 3 lb sledge, air hammer with chisel, and last time the HF SDS drill with SDS bit. All this on various masonry/cement projects. My reaction to the SDS drill: Holy Crap Batman!, as they say. Here's a LINKY This thing will bore a hole in about 5 seconds in the hardest concrete you've ever seen. No drift, nice clean hole. Effortless. Fast. Amazing. For $59 it's a total no brainer. Happy to lend you mine next time you have a need. Jan Link to comment
