doveguy1 Posted June 28, 2008 Share Posted June 28, 2008 can you puta six speedin a r1100rt? Link to comment
azpilot06 Posted June 28, 2008 Share Posted June 28, 2008 The consensus is that you can, but there's a fair amount of work involved, for what some feel is only a marginal gain. You'd also have to retrofit in a clutch master cylinder, slave cylinder, etc. For the additional expense, may be better off parting with the 1100 altogether and replacing with a 1150 or 1200. Link to comment
smiller Posted June 28, 2008 Share Posted June 28, 2008 Some would ask if you can install a 5-speed on an 1150. Link to comment
flars Posted June 30, 2008 Share Posted June 30, 2008 Yeah - five speeds rule. I prefer the 5 speed gearbox on my 1100RS to the 6 speed on my 1150RT. Always seems like I have to downshift a bunch more times to get to where the motor wants to be when riding around town. Link to comment
Jerry Duke Posted June 30, 2008 Share Posted June 30, 2008 I've had both and 6 speed rule! There were times running in the mountains I could never find a gear that fit some curves. The 6 speed is perfect! Link to comment
Ken H. Posted June 30, 2008 Share Posted June 30, 2008 Anything is possible, but in short you would have to replace nearly everything from the engine back. The tranny housing, rear sub-chassis, swing arm, drive shaft, final drive, clutch system, and rear brake system are all different R1100xx 5-speed to R1150xx 6-speed bikes. Link to comment
ShovelStrokeEd Posted June 30, 2008 Share Posted June 30, 2008 Anything is possible, but in short you would have to replace nearly everything from the engine back. The tranny housing, rear sub-chassis, swing arm, drive shaft, final drive, clutch system, and rear brake system are all different R1100xx 5-speed to R1150xx 6-speed bikes. Other than that, of course, it's a piece of cake. Link to comment
azpilot06 Posted July 1, 2008 Share Posted July 1, 2008 Just make sure that when you finally apply the 1.21 gigawatts needed to bring the beast to life, you loudly declare.. "IT......IS......A-LIVE!!!!!!" Link to comment
