Richard_D Posted May 15, 2008 Share Posted May 15, 2008 Subject: High-flying quality control too funny...and kind of scary! Just in case you need a laugh: Remember it takes a college degree to fly a plane, but only a high school diploma to fix one, a reassurance to those of us who fly routinely in our jobs. After every flight, UPS pilots fill out a form, called a 'gripe sheet,' which tells mechanics about problems with the aircraft. The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight. Never let it be said that ground crews lack a sense of humor. Here are some actual maintenance complaints submitted by UPS ' pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers. By the way, UPS is the only major airline that has never, ever, had an accident. P: Left inside main tire almost needs replacement. S: Almost replaced left inside main tire. * P: Test flight OK, except auto-land very rough. S: Auto-land not installed on this aircraft. * P: Something loose in cockpit S: Something tightened in cockpit * P: Dead bugs on windshield. S: Live bugs on back-order. * P: Autopilot in altitude-hold mode produces a 200 feet per minute descent S: Cannot reproduce problem on ground. * P: Evidence of leak on right main landing gear. S: Evidence removed. * P: DME volume unbelievably loud. S: DME volume set to more believable level. * P: Friction locks cause throttle levers to stick. S: That's what friction locks are for. * P: IFF inoperative in OFF mode. S: IFF always inoperative in OFF mode. * P: Suspected crack in windshield. S: Suspect you're right. * P: Number 3 engine missing. S: Engine found on right wing after brief search * P: Aircraft handles funny. (I love this one!) S: Aircraft warned to straighten up, fly right and be serious. * P: Target radar hums. S: Reprogrammed target radar with lyrics. * P: Mouse in cockpit. S: Cat installed. * And the best one for last P: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer. S: Took hammer away from midget. Link to comment
Boffin Posted May 15, 2008 Share Posted May 15, 2008 Yes I have always found those funny, ever since I saw them in the early 1970s on a hand-typed sheet and attributed to RAF ground crew Andy Link to comment
Mister Tee Posted May 15, 2008 Share Posted May 15, 2008 I didn't realize UPS put target radar in their airplanes either. Learn something new every day. Link to comment
Semper_Fi Posted May 16, 2008 Share Posted May 16, 2008 * P: IFF inoperative in OFF mode. S: IFF always inoperative in OFF mode. * OFF - On and Fully Functional - common mistake. This was a howl! Link to comment
