roydog007 Posted May 6, 2008 Share Posted May 6, 2008 I picked up a L102 & a Leslie, the gears are howling a bit. I think I need to get in there and oil them, with Hammond oil of course. Is this a major or minor project. Anything I should watch out for ? Link to comment
hANNAbONE Posted May 6, 2008 Share Posted May 6, 2008 i hAD a 1950's CV Hammond - full walnut case - up/down large key action...[ hard to do swells and runs 'cause it would beat up your hands too badly ] - the blinkin' thing weighed 800# and I still own the organ hauling eqpt. My back tells me that I loaded it many many many MANY times..! Anyway - oiling is no big deal. There are at least 1-3 "cups" that you pour a specified amount of oil into. You remove the rear wooden upper "plate" - the cover that hides the wiring and electronics...and you'll find the cups there. I believe the instructions are on the actual tube of oil you'll get. Don't overfill and when you load that hog - make sure it doesn't get cantted too far over or you'll have oil on places you won't want it. DAMHIK Link to comment
roydog007 Posted May 6, 2008 Author Share Posted May 6, 2008 Thanks, I've helped loading B3 s into truck at many a gig. This L102 isn't bad on the weight, shorter keyboard but I'm still getting a great sound through the Leslie. I'll check it out today when I get home from work. Thanks again Link to comment
