pbbeck Posted March 25, 2008 Share Posted March 25, 2008 I have a stripped screw that I don't know how to fix. I know the usual way to fix a stripped screw hole is to fill the hole with a material that matches the hardness of the surrounded material, but this screw holds a towel bar onto an aluminum shower door and is threaded into a piece of molded acrylic or plastic or some such material. I would love some ideas on what I can use to fill in the hole. Link to comment
STICKMAN Posted March 25, 2008 Share Posted March 25, 2008 How about a plastic anchor behind eveything???????? Link to comment
SteveB Posted March 25, 2008 Share Posted March 25, 2008 duct tape! Can you drill through the frame and attach a nut on the other side? If so you could epoxy a stud into the acrylic and use a couple washer to spread the load and match the finish of the alluminum. Link to comment
George Brown Posted March 25, 2008 Share Posted March 25, 2008 duct tape! Then go for a ride! Link to comment
Hermes Posted March 25, 2008 Share Posted March 25, 2008 don't sweat the small stuff, go ride. Link to comment
Jake Posted March 25, 2008 Share Posted March 25, 2008 My wife has a suggestion. Make the husband remodel the entire bathroom. Link to comment
steveknapp Posted March 25, 2008 Share Posted March 25, 2008 Is there aluminum for the shower door as well? Or just the plastic? I had some screws strip out on my shower door hinge (just over time the weight pulled the screws out. I replaced them with pop rivets and it's holding quite well. A picture would be really helpful. If you want to stay threaded, there are tons of threaded inserts. Either from a place like mcmaster, or some woodwoorking ones with some epoxy? Link to comment
Jerry Johnston Posted March 25, 2008 Share Posted March 25, 2008 My wife has a suggestion. Make the husband remodel the entire bathroom. Don't know the thickness of your shower door but you might be able to use a threaded pop rivet. They also make rubber pop rivets - they're 3/8" wide (hole size x 27/64" deep and use a 8/32" threaded bolt. I've used the rubber rivets to hold on roof racks on a car where I didn't want the roof to leak. They squeeze up nice and solid. Link to comment
