hmeiseles Posted March 12, 2008 Share Posted March 12, 2008 Hi all has anyone figured out the correct Odyssey Battery model for an 05 R1200ST? Thanks Link to comment
JR356 Posted March 12, 2008 Share Posted March 12, 2008 Hi, Don't know how different the battery box is,but the PC535 is the correct one for a R1200GS of the same vintage.You do have to trim a bit off the battery fins and possibly reroute some wiring that is close to the battery. I'd get the measurements for the 535 and see if it will fit. All the voltage,CCA,etc. specs are proper for the 1200 engine! See this post on Odyssey battery install. http://bmwsporttouring.com/ubbthreads/showflat.php/Cat/0/Number/1007987/an/0/page/0#Post1007987 Someone also installed a PC625 but it requires close consideration of seat fitting,as it's a taller battery and will interfere with the front seat support bar unless the center portion of the bar is removed as is shown here: http://www.r1200gs.info/misc/seat-trick.html Here is the PC625 install: http://www.advrider.com/forums/showthread.php?t=299269&highlight=PC625 Again this is a GS specific,but may apply to the ST depending on seat construction and battery box dimensions and placement. JR356 Link to comment
rew(r1200st) Posted March 13, 2008 Share Posted March 13, 2008 hi howard got the 535 for my st ,had to shave off the fins and do away with the batt strap,bend the connectors,but got it to fit.hope to her if there is one made for our bike.andy Link to comment
