drdave39 Posted March 8, 2008 Share Posted March 8, 2008 Has anyone aded heated seats to a non-heated OEM RT? I am picking up my 06 RT next week and have been thinking about doing this (especially if I decide to change saddles anyway). Is there an available wiring harness? Will it confuse the CANBUS? Would I be better off to do a relay-switched direct power setup to the battery, or...? Dave Link to comment
Ken H. Posted March 8, 2008 Share Posted March 8, 2008 Not on the RT, but I did it on our 12GS, which is the same electrical system. I powered and switched it independently, but understand that an aftermarket seat with the correct connector will plug in to the OEM harness. You have the OEM switch issue to add though. And the ZFE module may need to be programed that there is now a heated seat there by a dealer. Link to comment
Kritou Posted March 8, 2008 Share Posted March 8, 2008 Why not just make a heated pad for cold weather rides and chuck it in the cupboard during summer? I bought this DIY heated seat kit and had my local coach trimmer make a vinyl cover to match my saddle. It came with a fuse, panel switch and connector but I put a BMW plug on the end of the wire and power it from an auxiliary socket An elastic strap around the saddle holds it place when not in my Airhawk cover and a piece of rubber friction matting stops it sliding around Works just great and cheap as chips Link to comment
Rocket_Cowboy Posted March 8, 2008 Share Posted March 8, 2008 My 06 was originally not equipped with factory heated seats, and I added the OEM parts at the end of last year. The wiring is there on the main harness, so all I needed was the correct switchgear on the right hand bar, the short sub-harness that connects to the seats, and the seats themselves. Once all the parts were in hand, they had to reprogram the computer to tell it I had heated seats, and that got me the display on the dash. Wasn't particularly cheap ... would definitely be cheaper to add it right the first time, but on a used bike at the right price, it wouldn't be a bad thing at all. Link to comment
drdave39 Posted March 8, 2008 Author Share Posted March 8, 2008 Charley- what was the total cost? Do you have the part numbers? I'm thinking maybe I could get the switchgear and harness from a wrecked bike cheap... Link to comment
Don_Eilenberger Posted March 8, 2008 Share Posted March 8, 2008 Why not just make a heated pad for cold weather rides and chuck it in the cupboard during summer? I bought this DIY heated seat kit and had my local coach trimmer make a vinyl cover to match my saddle. It came with a fuse, panel switch and connector but I put a BMW plug on the end of the wire and power it from an auxiliary socket An elastic strap around the saddle holds it place when not in my Airhawk cover and a piece of rubber friction matting stops it sliding around Works just great and cheap as chips I like the idea - and was wondering - since the website doesn't give prices.. how much was "cheap as chips"? Link to comment
Kritou Posted March 8, 2008 Share Posted March 8, 2008 I bought mine from Aerostitch before I discovered who the OEM was and paid $87 - guess it would be cheaper from the manufacturer Link to comment
Phil49 Posted July 3, 2008 Share Posted July 3, 2008 Do you have to remove the fuel tank & other parts to plug into the harness? Thanks, Phil Link to comment
chaparral Posted July 3, 2008 Share Posted July 3, 2008 I put a Corbin on my 05 RT I has a switch on the left side and a 1 hour timer. The wiring included has a fused link and ya connect it directly to the battery No fuss no muss. Course after an hour ya hafta turn it on again for the next hour Chaparral Link to comment
swilson Posted July 3, 2008 Share Posted July 3, 2008 I also have a 1200RT that came w/o heated seats. I priced out adding the OEM switch/seat harness/shop time to reprogram bike to recognise heated seat and decided against it. I ended up Instead adding a Centech fuse block (which also came in handy to power extra lights up front, Hyperlites, and extra accessory socket) and used a Gerbing's permenant temp controller (got the dual version) to control the seat temp. Sure beats the on/off switch my previous bike had. Link to comment
drdave39 Posted July 4, 2008 Author Share Posted July 4, 2008 Scott, that's exactly what I have decided to do. I already have the Centech installed, so its just a matter of mounting the variable controllers. I also want to add a controller in the same location for the heated vest and wire it to control the 12V socket directly from the Centech (rather than the CANBUS. That way I'd have all my comfort controls in one place. Myybe some auxilliary light controls too! Dave Link to comment
