Ron_B Posted March 3, 2008 Share Posted March 3, 2008 I've got a problem with condensation within a double-glazed insulated window. Is there any way of fixing? Link to comment
ESokoloff Posted March 3, 2008 Share Posted March 3, 2008 Sorry, it's a goner The seal has been compromised. I had one go bad on me that had an aluminum frame. I disassembled it & had a local glass shop make a replacement pane. Before reassembling the new one, I applied extra sealant.... just in case. Edit: On second thought, you might be able to wait until you have a dry (ambient air) spell & see if you can get by with just resealing it after the moisture is driven out On mine, the inner aluminum spacer was perforated & appeared to contain a desiccant. Link to comment
LandonBlueRT Posted March 3, 2008 Share Posted March 3, 2008 I don't think so. The only solution I have ever found is replacement. Link to comment
T__ Posted March 3, 2008 Share Posted March 3, 2008 I've got a problem with condensation within a double-glazed insulated window. Is there any way of fixing? Ronald, it depends on how much work you want to put into it.. Years ago on my first house it had some rather cheap double-glazed insulated windows that would fog up inside (between the panes) especially the bathroom window.. I decided to make the repairs myself.. To do that I drilled a small hole in the glazing between the inner & outer pane then inserted a basketball inflator doohickey in that hole (it was a tight press fit).. I then hooked my A/C tank of Freon to that basketball inflator & lightly pressurized the cavity between the window panes.. I let that sit overnight to purge most of the air from between the glass panels.. Next day I used my A/C Freon leak detector & sniffed all around the window to find any leaks (found a few).. I marked the leakage points then hooked my A/C vacuum pump to the basketball fitting & pumped the air & moisture out (do this in the sun as a little heat will make the internal moisture boil in a vacuum).. With the vacuum still negative from the vacuum pump I used some tank sealer to seal the pin holes I had marked (no silicone calk available back then) Once I evacuated the space between the window panes again & the sealer had dried I again pulled it to negative pressure (vacuum) then used argon from my neighbors welding tank to fill the space between the panes.. Once full of argon I pulled the basketball inflator out & quickly pushed a plastic pin in the hole with sealer on it.. Not sure if the argon stayed between the panes or for how long but the window never fogged up between the panes again.. I did the kitchen window & a bedroom window the same way with the same results but never did get around to doing all the windows in that house.. Twisty Link to comment
tallman Posted March 3, 2008 Share Posted March 3, 2008 Please do not post these replies. My wife reads this forum and you're giving some of us, well, me at least, at bad name. Link to comment
Scribner Posted March 3, 2008 Share Posted March 3, 2008 not worth the trouble to fix. as most things in our lives are today, toss and get a new one. Link to comment
Paul_Burkett Posted March 3, 2008 Share Posted March 3, 2008 Ron, if your house is under 10 years old, there should be an "HOW" on it. That sounds like a manufacturers defect, also chech with your association to see if it is covered. Link to comment
BMWRich58 Posted March 3, 2008 Share Posted March 3, 2008 I've got a problem with condensation within a double-glazed insulated window. Is there any way of fixing? Time for new "lights".... Check the dates (found on the inside between the panes). Many manufacturers warranty or will Pro-Rate towards new one's. You'll be stuck with labor $$$. I've been doing this for the last 10 years on my home. Now I'm at the point of complete replacement window/frame. Link to comment
Hermes Posted March 3, 2008 Share Posted March 3, 2008 Hi Ron, how are you, I had three of them fog up in the last two years, ended up replacing them. Glas is pretty pricy, ouch. Then, last summer I went to a Farmshow here in Ontario and there was a fellow that was in the business of fixing fogged up double or triple glazed windows. Don't know what the process is called, don't know what the costs are, can't give you a name, I am just trying to make you aware of the fact that some entrepeneurs are out there to do that. Stay well, Jurgen Link to comment
steve404 Posted March 4, 2008 Share Posted March 4, 2008 Occasionally the fix can be put off for a while. Light bulb heat next to the lite with a vapor escape pin hole at the top of the frame. Link to comment
ShovelStrokeEd Posted March 4, 2008 Share Posted March 4, 2008 Ron, Finding and fixing the leak is the first part of the equation. I like the idea of using Freon and a leak detector. The vacuum idea is a good one as well but, at atmospheric pressure and near room temperatures, it will take a long, long time to get the water vapor out of there. Very persistent stuff, that. The trick to preventing condensation is to keep the pressure in the window above atmospheric by at least 10 to 20 torr (mm/Hg). That will keep the dew point within high enough so condensation will not take place. Best to use an inert gas in between. Nitrogen will do just as well as Argon and it's cheaper. Just watch the pressure, in both directions actually. Imploding/exploding window would be no joke. Link to comment
steveknapp Posted March 4, 2008 Share Posted March 4, 2008 Yee gads, anything is DIY fodder. I can have Karen find you the place that did ours. They did good work, but it was a hundred or two a window. Link to comment
DavidEBSmith Posted March 4, 2008 Share Posted March 4, 2008 Isn't anybody gonna point out that venting Freon into the atmosphere is bad for the environment? Ken? Link to comment
ESokoloff Posted March 4, 2008 Share Posted March 4, 2008 Isn't anybody gonna point out that venting Freon into the atmosphere is bad for the environment? Ken? And also illegal. A pet peeve of mine is that Freon® is DuPonts name brand of older refrigerants. Think Kleenex, Crescent, etc. Link to comment
Paul_Burkett Posted March 4, 2008 Share Posted March 4, 2008 Freon also contains mineral oil or other nasty lubricants that will do bad things to rubber window seals...like melt them. OUCH! Link to comment
T__ Posted March 4, 2008 Share Posted March 4, 2008 Freon also contains mineral oil or other nasty lubricants that will do bad things to rubber window seals...like melt them. OUCH! Paul, where did you get that idea? Not so.. Only new Refrigerant CONTAINING oil will have that in it (unless specified on the container it doesn’t) .. Re-claimed Refrigerant does contain some oil & other contaminants but not new.. Twisty Link to comment
Ron_B Posted March 4, 2008 Author Share Posted March 4, 2008 Yee gads, anything is DIY fodder. Yeah, I kinda figured there were ways, but I'm leery of trying to install do-hickys and messing around with vacuum and positive pressure. As an Instrument Maker/Machinist, I used to do a fair amount of scientific vacuum work, including UHV. (10 to the minus 9 torr) The things I made/worked on were usually stainless steel, and very seldom glass or ceramic, and certainly not glass with such a large surface area. As Ed pointed out, "imploding/exploding window would be no joke." One thing still stymies me: If the window contains a low vapor-pressure desiccant, (as I understand most do,) why won't the desiccant simply work (albeit slower) even after the leak screwed the window up? I think I'll wait till spring and just get it fixed. Thanks all. Link to comment
Paul_Burkett Posted March 4, 2008 Share Posted March 4, 2008 Twisty, you are right, I looked through the MSDS sheets and found that there isn't any oil in the virgin Freon, only that which is carried through the system. I stand corrected. Link to comment
ShovelStrokeEd Posted March 4, 2008 Share Posted March 4, 2008 There's an idea, Ron. Just slap a turbo molecular drag pump on it along with a good fat backing pump and have at it. When the window implodes, you can get a new one. For those of you who have never seen the stuff, 1" thick steel flanges with about 16-1/2" bolts around an 8" diameter flange, solid copper gaskets working with knife edges on the flanges and, if there is a view port, the glass is about 1.5" or so thick, tempered and not much more than 3 or 4" across. None of this has much to do with pressure differential (still only 14.7 PSI at sea level) but more to get stable seals. That said, a typical 30x40 window probably would implode at around 300 or 400 torr absolute, assuming the window would seal against that pressure differential. Link to comment
Shaman97 Posted March 7, 2008 Share Posted March 7, 2008 Isn't anybody gonna point out that venting Freon into the atmosphere is bad for the environment? Ken? ...and ~$17,000 fine per incident from the EPA. Reporting party gets a 50% bounty on the fine that is levied. Link to comment
