Limecreek Posted December 29, 2007 Share Posted December 29, 2007 I am off next Saturday and will open my garage to anyone needing service help, including changing tires. This will not be a full blown tech day. Work will be limited to the need of the group. And it will be first come first serve. I can crank things up at 8:00 and I'll go as long as we have work. You are responsible for your own parts and supplies. Sign up here and PM me for directions. I promise I will not cancel this one. Link to comment
JonathanE Posted December 30, 2007 Share Posted December 30, 2007 Thanks for the invite Greg, but I can't be there. Shucks, maybe next time. Where the heck is Austin anyways? (j/k, I was recently contacted by a hiring manager for a large corporation in Austin, but it's not where I can live, currently) Link to comment
eddd Posted December 30, 2007 Share Posted December 30, 2007 Currently I'm sitting in snowy Wisconsin, but I'll be home on the 2nd. I might take a ride up your direction. I don't need anything, but I'd be willing to help out. Link to comment
Limecreek Posted December 30, 2007 Author Share Posted December 30, 2007 (j/k, I was recently contacted by a hiring manager for a large corporation in Austin, but it's not where I can live, currently) You'd like Austin very much. There are quite a few Californians living here and working in the Tech sector. I may actually be leaving the area in the near term and will miss living here very much. Link to comment
Rocket_Cowboy Posted December 30, 2007 Share Posted December 30, 2007 Greg ... I don't have any work currently needing doing, but will try to make it down just to lend a hand and meet more of the texas guys. Austin is close enough for a day trip. Link to comment
Limecreek Posted December 30, 2007 Author Share Posted December 30, 2007 It will be good to see you Charlie. I'll have a set of the RTP brackets for you to look at while you are here. I'm going forward with plans to make copies and if the cost is reasonable will sell them for much less than the BMW bracket. Link to comment
Limecreek Posted December 30, 2007 Author Share Posted December 30, 2007 As of today we have one bike needing service for brake fluid change and final drive fluid change. I may also demo changing the clutch fluid on my bike. This will be my first time changing the fluid on the new generation RTs. Link to comment
eddd Posted December 30, 2007 Share Posted December 30, 2007 ...I may actually be leaving the area in the near term and will miss living here very much. Where are you heading, if we can ask? Link to comment
markgoodrich Posted December 30, 2007 Share Posted December 30, 2007 I'm not very experienced at a lot of the things that appear to be necessary, such as changing out the brake fluids, so I guess my first question is, Greg, is your deal this weekend appropriate for a neophyte needing a 12k service? My other questions have to do with what the heck is really needed for my RT at 12,000 miles. I have printouts of the BMW Motorrad maintenance schedules, and I'm confused. 1. It appears every 6k miles the oil should be changed, valves adjusted, and a bunch of minor checks done. 2. Then there's the annual, which adds gearbox oil change, complete brake fluid change, and more minor checks. 3. But then there's the "BMW Service with Annual Inspection (initially at 10,000 km, then every 20,000 km, annually), which is essentially the same list as the annual, with a bunch more checks. But then there seems to be a disconnect, as every 10k km one is to change gearbox oil, except when one does the list on number 3 above, which calls for the change at 10k km, then every 20k km thereafter. ????? Finally, how do we dispose of all these fluids? Link to comment
Rocket_Cowboy Posted December 31, 2007 Share Posted December 31, 2007 FWIW ... I've been dumping all my fluids every 12K. Overkill, but it's easier for me to remember. Link to comment
Limecreek Posted December 31, 2007 Author Share Posted December 31, 2007 Mark, I'll dispose of the fluid. It sounds like you are ready for just about everything--valves, sync, oil, gearbox, final drive and brakes. You'll need 4.2 quarts of oil and 2 quarts of GL-5 gear oil. If you want to do brakes on Saturday, arrive with your gas tank near empty. You'll need 2 pints of DOT 4 brake fluid. Make sure to ask for crush washers when you pick up your supplies. I'll have a 12K service sheet for you, so you can check it off as you go and take it with you for your documentation. Link to comment
RBowen Posted December 31, 2007 Share Posted December 31, 2007 Hello, I wish I could come and learn a few things but I'm afraid the significant other has made plans for me this weekend ! Let me know next time I really would love to learn a few basic skills! Randy Link to comment
Limecreek Posted December 31, 2007 Author Share Posted December 31, 2007 Randy, Look for a full blown tech days early in May. A pre Torrey tuneup. Link to comment
zbassman Posted December 31, 2007 Share Posted December 31, 2007 man, I wish I could join you but I'll be moving our datacenter from point A to point B this weekend. Link to comment
Rocket_Cowboy Posted December 31, 2007 Share Posted December 31, 2007 man, I wish I could join you but I'll be moving our datacenter from point A to point B this weekend. I've done enough datacenter moves, I can relate. Sounds like you'll definitely be up for (needing) a ride after next weekend. Link to comment
markgoodrich Posted December 31, 2007 Share Posted December 31, 2007 Mark, I'll dispose of the fluid. It sounds like you are ready for just about everything--valves, sync, oil, gearbox, final drive and brakes. You'll need 4.2 quarts of oil and 2 quarts of GL-5 gear oil. If you want to do brakes on Saturday, arrive with your gas tank near empty. You'll need 2 pints of DOT 4 brake fluid. Make sure to ask for crush washers when you pick up your supplies. I'll have a 12K service sheet for you, so you can check it off as you go and take it with you for your documentation. Okay, I'm in, will bring supplies, sledge, and other tools I have, but let's make sure you're clear, Greg: me, personally, I dunno NUFFINK. If this means it's too much for this particular event, please say so. Link to comment
Limecreek Posted December 31, 2007 Author Share Posted December 31, 2007 Mark, it will be entirely up to you. I can walk you through how to do something, but you will do the actual work on your bike, so if you fear it is too much, pick the procedure you'd like to learn and we will concentrate on that one. Link to comment
RBowen Posted December 31, 2007 Share Posted December 31, 2007 Sounds good! We are heading to Northern New Mexico and Colorado in June so the timing would be great Thanks Randy Link to comment
markgoodrich Posted December 31, 2007 Share Posted December 31, 2007 Mark, it will be entirely up to you. I can walk you through how to do something, but you will do the actual work on your bike, so if you fear it is too much, pick the procedure you'd like to learn and we will concentrate on that one. I guess I should have asked, "Will there be enough time for me to accomplish the entire list, given given my inexperience?" [i'm not quite the mechanical dunce I make myself out to be] Link to comment
Whip Posted January 1, 2008 Share Posted January 1, 2008 Killer and I are tryin to fit Austin into our busy schedule. I don't need anything, and please stay away from my bikes. .....unless you want to ride em. Whip Link to comment
Limecreek Posted January 1, 2008 Author Share Posted January 1, 2008 You're always welcome. I'll make up a big batch of kool-aid for ya. Link to comment
Rocket_Cowboy Posted January 1, 2008 Share Posted January 1, 2008 I don't need anything, and please stay away from my bikes. .....unless you want to ride em. Can I pre-order 2 hours of Tuono ride time please? Link to comment
eddd Posted January 1, 2008 Share Posted January 1, 2008 Back from snowy Wisconsin and ready for a ride. See you on Saturday. Link to comment
dawn Posted January 1, 2008 Share Posted January 1, 2008 Greg ... I don't have any work currently needing doing, but will try to make it down just to lend a hand and meet more of the texas guys. Austin is close enough for a day trip. I'm in the same position. You know where you're going? If I can convince Mike it is a good idea you mind a couple of tag alongs? I'm still 900 miles away from my next service. I need to crank through those before I head out to the MTF SMR so I can get the bike serviced before I go. This trip would put a little dent in those. I would like to learn how to do my own so when my warranty is over I can take it over. Link to comment
Rocket_Cowboy Posted January 1, 2008 Share Posted January 1, 2008 If I can convince Mike it is a good idea you mind a couple of tag alongs? No problem at all guys! Link to comment
steveknapp Posted January 3, 2008 Share Posted January 3, 2008 (j/k, I was recently contacted by a hiring manager for a large corporation in Austin, but it's not where I can live, currently) You'd like Austin very much. There are quite a few Californians living here and working in the Tech sector. I may actually be leaving the area in the near term and will miss living here very much. Austin kicks ass. Can't put my finger on it, but I love the place. Link to comment
Limecreek Posted January 4, 2008 Author Share Posted January 4, 2008 As of today, we have two bikes for service and about 6 other folks coming down to observe, hangout and drink coffee. The forecast is partly sunny and 73. Link to comment
ericfoerster Posted January 4, 2008 Share Posted January 4, 2008 I'd love to ride down this weekend but I've got tee times Sat and Sun. The weather should be great for post tech day rides Link to comment
markgoodrich Posted January 4, 2008 Share Posted January 4, 2008 I offered to bring donuts, but Greg said he's watching his waistline. What about us guys who can't find ours? If anyone wants to see it, I can bring a Sargent tank bag I'm going to return, as it's the same size as my current bag. They've knocked the price down from $180 to $95. Link to comment
Lawman Posted January 4, 2008 Share Posted January 4, 2008 Greg, You know I'd love to come...I have an alt. belt I'd like to change and get someone to show me how to work this zumo doo dad I just bought but I have to work a funeral on Sat...I'll be thinking of you guys...Have fun.. Link to comment
Whip Posted January 4, 2008 Share Posted January 4, 2008 I'd love to ride down this weekend but I've got tee times Sat and Sun. The weather should be great for post tech day rides Bring your clubs....I'll take ya out. Whip Link to comment
Skywagon Posted January 4, 2008 Share Posted January 4, 2008 Greg...new to the area. Moved to Houston in August..Haven't met any local BMW folks yet. Bike is just serviced but might like to ride down and meet folks. 2005 R1150RT. Please send info. Link to comment
Yeeha! Stephen Posted January 4, 2008 Share Posted January 4, 2008 Looks like I'm "in" for this one. Don't need anything done, but I'm gonna show up and visit, help, or get in the way... I haven't decided which yet See ya' when I get there. Link to comment
eddd Posted January 4, 2008 Share Posted January 4, 2008 I'm on the way. See you tomorrow. Link to comment
Yeeha! Stephen Posted January 5, 2008 Share Posted January 5, 2008 Sorry, I'm out. Got called back to work. Maybe next time... I miss yooz guyz! Link to comment
Buckster Posted January 6, 2008 Share Posted January 6, 2008 Had a excellent time. Learned a lot with great folks. Thanks Greg. Nice to meet everyone. Bob Buck Link to comment
dawn Posted January 6, 2008 Share Posted January 6, 2008 What a beautiful day! Thanks for letting me get in the way guys. Highly educational day for me and a fantastic day for a ride. Greg, my e-mail addy for those zip files is dpenning@gmail.com Thanks so much! Link to comment
markgoodrich Posted January 6, 2008 Share Posted January 6, 2008 Many thanks not just to Greg, but to his lovely wife Sandy for letting us take up the family's Saturday. I could never have done a tenth of the stuff we did today without the able and friendly assistance of Greg, Bob, Edd, et al. Be sure to vote HERE for the most appropriate renaming of yours truly. Link to comment
eddd Posted January 6, 2008 Share Posted January 6, 2008 Got back home at 10:30. Smooth ride all the way. Thanks Greg and Sandy for offering your lovely home and your time. I enjoyed meeting everyone. Communicating through the board is great, but it sure can't compare to getting together. I'll check my pictures in the morning and post a few. Link to comment
eddd Posted January 6, 2008 Share Posted January 6, 2008 Here are a few more pictures from the day's activities. Please excuse the the less-than-perfect photo quality. Mark, Dawn, and Greg are working on Mark's brakes. This is before we took a break, but it was after the bolt had broken. Here is Bob's bike, and though you probably can't tell (or least I hope you can't tell ) that is Bob in the picture. Sorry, Bob. This was the only shot from this angle that wasn't washed out by the sunlight. Herman's immaculate RT is the one in the background. Here is a little more flattering picture of Bob (Buckster). Herman was there to learn about servicing his brakes and his "lifetime" final drive. Dawn rode down from Dallas on her R1200RT. Notice her custom footwear near the rear tire. Here is Dawn's clever solution to being sure she can flat-foot her bike. She told us that lowered shocks are in the plans. Herman's RT looks like it has been to the chop shop. Mark was wondering if Herman would notice if one of his caliper bolts were to mysteriously disappear. Herman's "lifetime FD" has reached it reached it's lifetime. That was fast, only 7,000 miles. Later in the afternoon we were honored with a vist from Killer and Whip. Whip avoided the hoards of paparazzi, but Killer strikes a pose astride the Touno. Link to comment
Bob Palin Posted January 6, 2008 Share Posted January 6, 2008 Zog say "Tuono Fun". Good to see everybody, Whip was pretty sneaky riding the Tuono on the way there, on the way home it was too dark and deery to have any real fun. Link to comment
eddd Posted January 6, 2008 Share Posted January 6, 2008 Zog say "Tuono Fun". Good to see everybody, Whip was pretty sneaky riding the Tuono on the way there, on the way home it was too dark and deery to have any real fun. Gee, I wonder if that was planned?? Link to comment
Angel Posted January 6, 2008 Share Posted January 6, 2008 Sounds like a great & productive time had by all. I am sorry I missed it! I'm sure I could have gotten in the way somewhat.... or perhaps even maybe attempted a throttle body synch. Oh well, there's always the next time. Even though I missed this one... Thanks Greg for once again sharing your knowledge, tools and garage! ps. is it too early to start talking about the '08 hill country ride? Link to comment
Limecreek Posted January 6, 2008 Author Share Posted January 6, 2008 ps. is it too early to start talking about the '08 hill country ride? Last year was my last year as organizer--I'm retired. Someone else will need to step forward and take it over. Perhaps someone from the Dallas crew? hint hint Link to comment
