Rob L Posted October 21, 2007 Share Posted October 21, 2007 I noticed that my high beam was not focused very well. An inspection revealed that the bulb was not seated properly. I popped off the cover and removed the bulb, however the metal piece remained in the headlight assembly and the plastic piece had a broken "ear." I spent the last 6 hours working on the bike! I removed the entire headlight assembly to see exactly what could be done. Happily I figured out a cure which is less than $413 , the cost of the new parts! I assembled the metal socket and plastic "keeper" with a new bulb and temporarily held them together with a plastic tie strap. I then drilled a small hole through both pieces on 2 sides opposite of each other. I used 2 small pop rivets to hold the pieces together and removed the tie strap. I needed to file the head of the rivets slightly to allow the assembly to fit back in the headlight. 6 hours later......the light works as good as new Link to comment
