RoadJunkie Posted September 26, 2007 Share Posted September 26, 2007 Has anyone replaced their grips (heated) on the R12RT? What do I need to watch out for in this process? Link to comment
bobbybob Posted September 26, 2007 Share Posted September 26, 2007 Has anyone replaced their grips (heated) on the R12RT? What do I need to watch out for in this process? Why replace them--are they defective? Mine are--been to the dealer 4 times and still intermittent. They have replaced the ZFE among other things such as re-programming, etc.--next step will be either the complete wiring harness or the grips/electronics themselves. 2007 R1200RT. Link to comment
towboatguy Posted September 26, 2007 Share Posted September 26, 2007 I've replaced the ones on my ST after I screwed up the originals when I put Renthal grips on (worked fine on my R1150R, 650GS, and every other bike I've had recently). On the ST (and I would presume the RT) the grips and switch assemblies are fairly complicated, several tiny torx screws and wire connectors to deal with. Not all that bad, really, just keep track of everything and take care not to lose any of the little screws. Ed Link to comment
AZRTRDR Posted September 27, 2007 Share Posted September 27, 2007 I just replaced mine with a pair from an 07 Triumph Rocket3. I did it for the feel that I wanted. Cut the old ones off with a scissor. Use caution as to not damage the heating wires beneath. I put a piece of tape to protect the heater wire and used hair spray as a lube. Worked the new grips on and I'm a smilling. Link to comment
Ken H. Posted September 27, 2007 Share Posted September 27, 2007 Have you considered covering them instead? Grip-Tex and others make covers that slide over, don't interfere with the heat function, you don't risk breaking the heating element in the process, and they can be renewed again and again. Link to comment
AZRTRDR Posted September 27, 2007 Share Posted September 27, 2007 I did try them. They just did not work as well with the tapered grip shape as I cared for. Worth a try for others though. Inexpensive too. Link to comment
