richrob Posted September 25, 2007 Share Posted September 25, 2007 was using a touratech for my sp-3. good mount, but blocks instruments on my 1150rt. Now have a 2720 and was thinking of a mount on the left side. anyone have a suggestion, and or, experience with a ball mounted bracket. appreciate any input. thanks, Richie Link to comment
MattP Posted September 25, 2007 Share Posted September 25, 2007 Do a search on "Post Your GPS Mounting Pictures Here". There's a great thread on a lot of different options. If you are thinking you want it on the left side, I would do a RAM mount on either the clutch resev, or use the mount that utilzes the alternate mirror mounting hole on the left grip/switchgear. Link to comment
richrob Posted September 26, 2007 Author Share Posted September 26, 2007 Matt, thanks for the reply. much appreciated. Link to comment
jakfrost Posted September 26, 2007 Share Posted September 26, 2007 Then there is this option...made it for myself when I got fed up looking for a 'non-invasive' clean, centered installation for my Garmin 376c. I have 3 left of the few I made for friends on the board...62.00 includes shipping, 1" Ram ball mount and solid billet aluminum base. Its a 'press fit', no holes to drill or screws to screw Plus you can see it over the BMW tankbag, and it doesn't block the guages Click to enlarge... Jim Link to comment
Jacques Posted October 1, 2007 Share Posted October 1, 2007 Is it suitable for the Zumo550 as well? I have a r1200rt. In that case I will be interested. Jacques Link to comment
hopz Posted October 1, 2007 Share Posted October 1, 2007 If you are not familiar with the Zumo Forum, may I suggest you take a look over there. This link is to my photos of my install on a R1200RT. http://www.zumoforums.com/index.php?topic=2798.0 This solution costs about $15 for the mount. There are many wiring solutions. If the photos do not load- email me and I will send larger shots directly to your email. Link to comment
MarkEngland Posted October 1, 2007 Share Posted October 1, 2007 You might consider a BMR Shelf. I like mine a lot and it serves many purposes. Here is BMR Products page for the shelf: http://bmrproducts.com/products.php?cat=6 Here is my webpage with my install. http://www.kc6tew.com/modifications/rtmods/bmrshelf/bmrshelf.html Mark Link to comment
jakfrost Posted October 2, 2007 Share Posted October 2, 2007 Its perfect for the Garmin Zumo 550. In fact I have seen my little mount used more often for the Zumo than any other GPS. I just don't have a picture of one...maybe one of the members who bought my mount will put one up? Jim W. Link to comment
Hoover Posted October 2, 2007 Share Posted October 2, 2007 Not sure if you use a tankbag, but I bought a $3 piece of plexiglass from the Home Cheapo and put it in the rain cover pouch in front of my tank bag. I then used the windshield mount that came with my GPS unit and it works fantastic. This is not a great pic of the GPS, but is the only one I have where it is visible. It's totally out of the way of all gauges, although it is goofy turning the bike on and off when the GPS unit is mounted. Link to comment
IanW Posted October 2, 2007 Share Posted October 2, 2007 Ram mounts has your answer: http://www.ram-mount.com/products/motorcycles.htm Ian Link to comment
JMR Posted October 7, 2007 Share Posted October 7, 2007 Then there is this option...made it for myself when I got fed up looking for a 'non-invasive' clean, centered installation for my Garmin 376c. I have 3 left of the few I made for friends on the board...62.00 includes shipping, 1" Ram ball mount and solid billet aluminum base. Its a 'press fit', no holes to drill or screws to screw Plus you can see it over the BMW tankbag, and it doesn't block the guages Jim I can speak for this mount personally...I saw it mentioned in a post, contacted Jim (jakfrost) and have been using mine for almost a month now....it's great! I have both the short and med RAM post, but use the short one most of the time. I go back and forth between the BMW tank bag for the 12RT (which is big and tall) and the Touratech Flat Tank Bag for the 12RT (which is shorter)...the mount works very well with both bags. Well made. Puts the mounted item up front and center, but not blocking the view of anything else....I recommend! Link to comment
Mike05 Posted October 8, 2007 Share Posted October 8, 2007 Then there is this option...made it for myself when I got fed up looking for a 'non-invasive' clean, centered installation for my Garmin 376c. I have 3 left of the few I made for friends on the board...62.00 includes shipping, 1" Ram ball mount and solid billet aluminum base. Its a 'press fit', no holes to drill or screws to screw Plus you can see it over the BMW tankbag, and it doesn't block the guages Jim +1 Have had one of these for over six months. Absolutely no complaints; does the job very well (I use the "short" arm in conjunction with a BMW Tank Bag) & easy to install. Link to comment
