Col Posted September 24, 2007 Share Posted September 24, 2007 I found this rubber cap under the bike, R1200RT. Don't know if it fell off or is from something else. Does anybody recognise it? Thanks Col Link to comment
Ken H. Posted September 24, 2007 Share Posted September 24, 2007 I don't think that's a BMW part. The markings are don't seem right. Could be wrong though... Link to comment
Fran Posted September 24, 2007 Share Posted September 24, 2007 I found the same cap, I once remember seeing it somehwere on the bike, I don't recall where. Fran Link to comment
Boffin Posted September 24, 2007 Share Posted September 24, 2007 I recognise the logo, FTE is a German brake manufacturer. As to which part of the braking system, I do not know. web page Andy Link to comment
erkmania Posted September 24, 2007 Share Posted September 24, 2007 It's a cap for the brake fluid filler check valve on the front brake circuit. Follow the front brake line from the master cylinder to the banjo bolts at the fluid manifold by the steering neck. One of the banjos is distinctly different. That's where the cap goes. It's not a mission critical part, so you don't have to worry too much; my RT lost its cap in the showroom. Hope this helps. Link to comment
Col Posted September 24, 2007 Author Share Posted September 24, 2007 It's a cap for the brake fluid filler check valve on the front brake circuit. Follow the front brake line from the master cylinder to the banjo bolts at the fluid manifold by the steering neck. One of the banjos is distinctly different. That's where the cap goes. It's not a mission critical part, so you don't have to worry too much; my RT lost its cap in the showroom. Hope this helps. Thank you! Wonder why it fell off? Col Link to comment
IanW Posted September 24, 2007 Share Posted September 24, 2007 It's a cap for the brake fluid filler check valve on the front brake circuit. Follow the front brake line from the master cylinder to the banjo bolts at the fluid manifold by the steering neck. One of the banjos is distinctly different. That's where the cap goes. It's not a mission critical part, so you don't have to worry too much; my RT lost its cap in the showroom. Hope this helps. Thank you! Wonder why it fell off? Col Col I had the same problem, found it on the garage floor after working on the bike, had me stumped at first then found the spot. Ian Link to comment
Effjay Posted September 24, 2007 Share Posted September 24, 2007 That's easy... yesterday was the 1st day of FALL"! Link to comment
blkvelvt Posted September 25, 2007 Share Posted September 25, 2007 That's easy... yesterday was the 1st day of FALL"! Badump chish (rimshot) Link to comment
