Mike05 Posted September 23, 2007 Share Posted September 23, 2007 Anyone know if you can mount a (Garmin) Xm Antenna under the Tupperware (R1200RT)?? Currently atop a brake reservoir in the open & works fine. The issue is, disconnecting it from behind the Zuno 550 whenever I park the bike out of site for a few hours. If it'll work, would rather mount "permanently" under the plastic. Link to comment
johnlt Posted September 23, 2007 Share Posted September 23, 2007 It may work but you should test it first. The XM signal is a pretty weak signal and any mass can attenuate it. Theoretically, the plastic is "transpearent" but like any ray dome, there is a small amount of attenuation. Link to comment
Firefight911 Posted September 23, 2007 Share Posted September 23, 2007 I have my XM antenna mounted under the right fairing cover on my R12ST. No issues other than a periodic signal loss during right hand, "high" lean angles when that side of the bike is pointed more North than South. Wow!! Just reread that. I need to get out more! Link to comment
awagnon Posted September 23, 2007 Share Posted September 23, 2007 I assume the XM antenna is about as sensitive or non-sensitive as the SIRIUS antenna which I mounted under the upper dash panel of my 1150RT. Works fine regardless of which direction I'm riding. Link to comment
Les is more Posted September 23, 2007 Share Posted September 23, 2007 Likewise with the Delphi XM antenna. We have it under the upper dash of the 1150RT with no problems. Link to comment
MLS2GO Posted September 24, 2007 Share Posted September 24, 2007 HD mounts the XM antenna inside the front fairing of its touring bikes. I've had it in two places. My experience is to keep it away from any metal, more in the open inside the plastic is better than right up agains metal. The metal in the right situations will hurt the signal. Link to comment
Mike05 Posted September 24, 2007 Author Share Posted September 24, 2007 Thanks everyone; enough information now to proceed! Link to comment
rdsmith3 Posted September 24, 2007 Share Posted September 24, 2007 It also depends on where you ride. If you are in an area with a lot of ground repeaters, the mounting position is much less critical. Link to comment
