KiwiRiden Posted September 22, 2007 Share Posted September 22, 2007 I was doing my first valve adjustment and when I took off the valve covers, I noticed that two of the rubber grommits that sit on the bolts have moved out of place. Is this anything important and if so, how do I fix it? One of the grommits is a bit chewed up as well so it may need more than a cunning plan to put them back in the right place. Link to comment
Ken H. Posted September 22, 2007 Share Posted September 22, 2007 I was doing my first valve adjustment and when I took off the valve covers, I noticed that two of the rubber grommits that sit on the bolts have moved out of place. Is this anything important and if so, how do I fix it? One of the grommits is a bit chewed up as well so it may need more than a cunning plan to put them back in the right place. If they won't push back, new ones are probably needed. Link to comment
Rider1200RT Posted September 22, 2007 Share Posted September 22, 2007 I agree and they will need replacement. These things can be a source of leakage. I replaced one under warranty and it looks like it is leaking again.... Link to comment
