rickman125 Posted August 28, 2007 Share Posted August 28, 2007 I am trying to get the radio out of my 96 RT. I am using 4 wires the size of the holes at either end of the radio. I can feel a little click when the wires are pushed in but the radio will not come out. Is there another way to do this? Or am I doing it wrong. Link to comment
Bill_Walker Posted August 29, 2007 Share Posted August 29, 2007 Wires won't do it. You need something stiff. The removal tools are cheap, though. Any car stereo place should have them. They need to be inserted to the click and then pushed toward the outside, i.e., away from each other (IIRC, if not push 'em toward each other) to release the locking tabs that hold the radio in the sleeve. Link to comment
Mark K Posted August 31, 2007 Share Posted August 31, 2007 A Ford or Mazda radio removal tool will work. That's what I have used sucessfully. I completely removed my radio, so I no longer need them. PM me if you would like me to send them to you. That said, the wires your are using should still work as long as you can leave them pushed in past the "click" while lifting the unit from some other point. Link to comment
rickman125 Posted September 1, 2007 Author Share Posted September 1, 2007 I have some brazing rod that fits the hole very well. I can feel a click each time I put them in but the radio will not come out. Link to comment
Leo Posted September 1, 2007 Share Posted September 1, 2007 I found that the radio was very stiff in the carrier. Already had tupperware off for other tasks so removed radio carrier and gently used flat screwdriver to prise it out. All back in and still works. Link to comment
