brianbmw Posted August 27, 2007 Share Posted August 27, 2007 Are there any suspension experts out there. I'm just trying to get mine set up for my weight 170lbs. Right now it seems stiff. When i'm adjusting should i go one click and then try, or maybe 2 clicks. I'm just not sure how much to adjust before i try it. Also is there a baseline to start from? The manual mentions a 187lb rider but i don't know how many clicks less i should be. Link to comment
Wicker Posted August 27, 2007 Share Posted August 27, 2007 If you have the standard BMW rear shock there should be a series of gradation marks on the shock behind big plastic adjuster knob. If you fully turn the adjuster to the low setting the standard setting is clearly marked (a red line) about half way in. I am a bit heavier than you (190lbs) and just tend to use the standard BMW setting unless I am carrying panniers when I turn another 3 turns towards the high setting. I have found the bike quite softly sprung on anything less than the standard setting. When fully loaded with rider and panniers even standard is too soft: I recently found the rear was squatting down too much at speed on the German Autobahn leading to the front feeling light and starting to weave slightly around 110mph. Ride was far more composed on a harder shock setting. Link to comment
bakerzdosen Posted August 27, 2007 Share Posted August 27, 2007 Well, after carefully searching, I couldn't find any copyright information on the following ( ) information, but this is what I got from Phil (1bmwfan): ONE UP Spring Preload: + 20 clicks from minimum Damping Screw: -1-3/4 turns from maximum Tire Pressures: 36 Front, 38 Rear ONE UP W/ LUGGAGE Spring Preload: + 25 clicks from minimum Damping Screw: -1-1/2 turns from maximum Tire Pressures: 36 Front, 38 Rear TWO UP Spring Preload: + 30 clicks from minimum Damping Screw: -1 turn from maximum Tire Pressures: 38 Front, 40 Rear TWO UP W/ LUGGAGE Spring Preload: + 35 clicks from minimum Damping Screw: -3/4 turn from maximum Tire Pressures: 40 Front, 42 Rear I found that that info is a great starting point. I really hope Phil doesn't mind me posting it (if so, sorry man). I know he just went out and rode the thing until he arrived at these numbers. If you're wanting to adjust things, I would guess it depends on how sensitive that you are. If you're really picky about things, I'd try one click on the preload and 1/4 turn on the dampening and see how that changes things. Link to comment
Timmer Posted August 27, 2007 Share Posted August 27, 2007 Phil shared the same settings with me last year and I found them to be a pretty good starting point. Link to comment
Ben_Ricci Posted August 28, 2007 Share Posted August 28, 2007 Thanks for posting Phil's settings. I've been wondering where to start. I'm a smudge over 140 lbs., but I carry lots of junk in my side cases and tank bag I hope I'll never need. It's the snowblower theory. Buy a snowblower and it won't snow: carry a bunch of tools and you won't breakdown. Link to comment
Firefight911 Posted August 28, 2007 Share Posted August 28, 2007 Thanks for posting this Matt!! Since our computer died last week, I can't access my hard drive. Waiting for the new one to show up. I am relegated to the work computer for access and Jamie's work laptop that she brings home after work when I am home. Just an FYI, these settings were derived from riding around for a 205 lb. rider (weight before riding gear). Hope these help out to get you started. Does this mean that after 3000++ posts, I actually contributed something worthwhile???? Link to comment
bakerzdosen Posted August 28, 2007 Share Posted August 28, 2007 Just an FYI, these settings were derived from riding around for a 205 lb. rider (weight before riding gear). Hope these help out to get you started. Does this mean that after 3000++ posts, I actually contributed something worthwhile???? Yup - I suddenly don't feel so bad about my weight. Link to comment
Ben_Ricci Posted August 28, 2007 Share Posted August 28, 2007 Hmmmm. And I don't carry around 60 pounds of ballast. Thanks for the clarification. Link to comment
