kinchy Posted August 25, 2007 Share Posted August 25, 2007 You do your own service. You have a problem thats unrelated to fluid changes and valve/TB adjustments. Will any problem be associated with the owner doing the service thus leading to a showdown? Link to comment
bobbybob Posted August 26, 2007 Share Posted August 26, 2007 Kinchy, find that service contract that proves you have the ext. warranty; then get out your magnifying glass and a strong light, then turn it over and try reading the very faded, very fine print on the back. At least this was MY introduction to the Yamaha ext. warranty for my FJR1300. Unless it specifically states that all maintenance must be done at a dealer, you are fine doing it yourself. Of course, if something breaks as a result of doing it yourself, and it's obvious, you'll have no one else to fall back on. FYI, I declined mine simply because it was so restrictive that I had trouble finding something it would actually cover. "Normal wear & tear" items suddenly took on a whole new meaning on the ext. warranty, much different than the OEM's original warranty. Good luck! Link to comment
Bob Palin Posted August 26, 2007 Share Posted August 26, 2007 Wasn't a problem for me when they replaced my transmission, didn't ask any questions at all. Link to comment
flyingreg Posted August 26, 2007 Share Posted August 26, 2007 You do your own service. You have a problem thats unrelated to fluid changes and valve/TB adjustments. Will any problem be associated with the owner doing the service thus leading to a showdown? There normally is no problem. IMO, allot depends on how the repair is presented to the insurer by the dealership. Most dealerships will want to sell the repair to the insurer since the dealership will be doing the repair work. Link to comment
