johnlt Posted August 18, 2007 Share Posted August 18, 2007 I just received an HID kit for the high beam on my 12RT. Looks pretty much plug-and-play but I do have to mount the ballast. Would appreciate recommendations on mounting locations and method. tks Link to comment
sevenup Posted August 18, 2007 Share Posted August 18, 2007 you don't say if you have a bmw radio fitted. On my 1150 rt I mounted both ballasts in the speaker cavity on either side as had no radio. on the 1150, I used the screws that held the speedo/rev counter in place. not sure if the 1200rt has an equivalent there. Link to comment
Dick_at_Lake_Tahoe_NV Posted August 18, 2007 Share Posted August 18, 2007 I ordered the single-light unit for the High-beam only. I mounted the ballast on top of the support bars right behind the high-beam headlight. Then I put a big metal clamp around it and a couple of Zip ties. Seems to ride there with no problem. Link to comment
johnlt Posted August 18, 2007 Author Share Posted August 18, 2007 Thanks Dick, I'll give that a try, jlt Link to comment
Heck Posted August 18, 2007 Share Posted August 18, 2007 Thanks Dick, I'll give that a try, jlt Also make sure that your suspension clearances are ok...it is a tight area.. you'll like the HID...I did one on the low beam.. Good luck Link to comment
CruisinCruzan Posted August 18, 2007 Share Posted August 18, 2007 I have 4 HID ballasts all mounted under the dash on my '06 without any fit problems. I do not have the BMW radio. Link to comment
