John in NC Posted August 14, 2007 Share Posted August 14, 2007 Who makes the ABS controller for the 2004 RT? Link to comment
T__ Posted August 14, 2007 Share Posted August 14, 2007 Who makes the ABS controller for the 2004 RT? John, that's a good question on who ACTUALLY manufactures controller,, AFAIK the original ABS 2 design & testing was done under a joint agreement between BMA & FAG Kugelfischer.. I would presume BMW or FAG manufactures the unit itself but there is also the chance it could be done by an outside supplier under license.. FAG is more of a bearing & sensor supplier though.. Twisty Link to comment
John in NC Posted August 14, 2007 Author Share Posted August 14, 2007 Thanks for the response and info. There has got to be a source for the screw in caps on the ABS unit other than the dealer. $43 is just out of the question. Link to comment
T__ Posted August 14, 2007 Share Posted August 14, 2007 Thanks for the response and info. There has got to be a source for the screw in caps on the ABS unit other than the dealer. $43 is just out of the question. John, have you tried Beemer Bone Yard? Twisty Link to comment
RichK Posted August 14, 2007 Share Posted August 14, 2007 John, are you looking for the screw-in cap to fabricate a fill device for ABS brake bleed? If so, some members of this board have commented that they have successfully used a rubber stopper rather than the much more expensive screw in filler cap. Link to comment
