Arizona_oldguy Posted July 9, 2007 Share Posted July 9, 2007 My 06 R1200rt runs smoothly, gets 50 plus mpg on the hwy, seems fine otherwise, but when I try to accelerate hard, like dropping to 3rd or 4th to pass a truck, she acts like one cylinder isn't working at all, bucks and stumbles. If I accelerate slowly no problem. Any suggestions? She is getting close to the 12000 mile service. Glenn Link to comment
Ken H. Posted July 9, 2007 Share Posted July 9, 2007 If it is recording a failure, which given these symptoms I suspect it would have, the dealer should be able to see it with their GT-1 diagnostic system. Or purchase the GS-911 and check for recorded codes yourself! Link to comment
David Posted July 9, 2007 Share Posted July 9, 2007 I'd check the fuel filter or pump. Link to comment
Arizona_oldguy Posted July 9, 2007 Author Share Posted July 9, 2007 I don't know if the bike is recording anything, there is no engine warning light coming on at all. Glenn Link to comment
Guzzidave1998 Posted July 9, 2007 Share Posted July 9, 2007 Hi Glenn Maby you got ahold of some bad gas that could do it. Link to comment
Timmer Posted July 9, 2007 Share Posted July 9, 2007 I had the same thing on my R1200ST. It turned out to be one of the dual spark plugs on the underside of the left cylinder. The insulator had broken and it was shorting to the head under hard acceleration. You may want to check the spark plugs and the plug wires. Link to comment
marcls Posted July 9, 2007 Share Posted July 9, 2007 I have the same symptoms on my '05 R1200RT - ~51 mpg, smooth at constant highway speed and during mild acceleration, but stumbling and bucking under hard acceleration. It can't be the gas because it's consistent whether I use 91 octane or 100 octane. My dealer thinks it's one of the ignition coils, and I have an appointment to have it changed this Friday. If there's interest, I can report on the results after my service appointment. Marc Link to comment
Arizona_oldguy Posted July 9, 2007 Author Share Posted July 9, 2007 Hi Tim, Thanks for those suggestions, it feels like it is more likely a spark failure than a fuel problem. I will check that out. Glenn Link to comment
Arizona_oldguy Posted July 10, 2007 Author Share Posted July 10, 2007 Hi Tim, So what do I need to know, or tools to have, to check/change spark plugs on R1200t? Glenn Link to comment
