SinNH Posted July 4, 2007 Share Posted July 4, 2007 So I need replace the stock tensioner on my 00, been checking the threads, seems easy enough. But just want to make sure I have the part numbers straight to do the left, the right will happen this winter. Thanks, Steve 1--07119963308 seal ring 1--11317656922 piston 1--11317688629 cylinder also I'll install,,, 1--13541341797 T-body oring 1--13642351881 injector bottom 1--13641730767 injector top Is this all I need ? Link to comment
Stan Walker Posted July 4, 2007 Share Posted July 4, 2007 The first four numbers are identical to what I just ordered from Chicago BMW. Can't speak for the last two. Stan Link to comment
BluegrassPicker Posted July 5, 2007 Share Posted July 5, 2007 FYI this little tool that fits in a socket is the perfect tool for the job. Just did mine two weeks ago. I bought it at Sears. Also note that the new part takes a smaller socket than the old part. Link to comment
SinNH Posted July 5, 2007 Author Share Posted July 5, 2007 Can't speak for the last two. Stan I should have labeled them o-rings too, I figured I'd replace those because I'm in there. thanks all Link to comment
BUSTED Posted July 6, 2007 Share Posted July 6, 2007 I've done a few without removing the TB. pic attached of tools I used. Link to comment
