moshe_levy Posted July 4, 2007 Share Posted July 4, 2007 All- After previewing the excellent R1200 Maintenance DVD, I used the technques therein to breeze through a valve adjustment on my GF's 2004 R1150R. However, I'm still using individual Wurth feeler gauges - you know, the ones with the color-coded handles. What Jim did on the DVD was to use one long feeler gauge for each respective side (exhaust and intake,) spanning the length between both valves on that side. In this way, pulling on the gauge from the middle, he could really feel if both valves on that respective side were identically set. Sure seems more accurate than using two separate gauges, at least for this newbie. So tell me - where can I get a set of longer gauges like this? The local auto parts store had nothing, so I'm all ears! -MKL Link to comment
psmoss Posted July 4, 2007 Share Posted July 4, 2007 How about: http://tinyurl.com/2wue8k Link to comment
Jim VonBaden Posted July 4, 2007 Share Posted July 4, 2007 I picked up a set at Autozone, and found another set at Pepboys. They come stuck in a set and I just remove the two I need to cary with me. Here is one online source. Thanks for the kind words Moshe! Jim Link to comment
