Samzilla Posted July 2, 2007 Share Posted July 2, 2007 For those of you who use a fuse panel for your accessories, where did you mount it on your R1200RT? Link to comment
gettysburg Posted July 2, 2007 Share Posted July 2, 2007 I mounted a Blue Sea 5025 fuse block behind the front right speaker grill. It's attached to the frame with 4 large zip-ties. If you don't have the stereo on your RT, there's plenty of room behind the instument panel where the speakers would normally be located. Since any gadget I'm likely add will be installed up front, it made more sense to me to have the fuse box up font; rather under the seat. It will save me from having to fish multiple sets of wires under/around the gas tank. Link to comment
keithb Posted July 2, 2007 Share Posted July 2, 2007 My Centech is velcro'ed on the top left side of my battery. Link to comment
sevenup Posted July 5, 2007 Share Posted July 5, 2007 For the absence of doubt (mine), I need to understand the fitting of the centech panel. I pick up my bike in 10.5hrs (and a few minutes) (a 1200rt se with everything except the radio). I have bought a centech and had intended to fix it to the battery directly. Is this possible. I intend using a Starcom and a heated jacket for my wife. I need to ask cos, the centech paperwork mentions canbus issues and I've never seen the system never mind fiddled with it. Any and all advice appreciated. oh! the bike is Silver with a black engine fairing. Link to comment
keithb Posted July 5, 2007 Share Posted July 5, 2007 Richard My centech panel is wired directly to the battery with 14 gauge wire (pretty heavy stuff). My 2 sets of running lights, radar detector, and future GPS/satellite radio are wired directly to the ports on the fuse panel. I then velcro'ed the panel on top of left side of the battery so it can be moved when wrenching is necessary. I will try and send you some pics of my setup. I have to change computers to do this. Hope this helps. Link to comment
sevenup Posted July 5, 2007 Share Posted July 5, 2007 thanks keith. I look forward to that. Link to comment
Aluminum_Butt Posted July 5, 2007 Share Posted July 5, 2007 I have bought a centech and had intended to fix it to the battery directly.....the centech paperwork mentions canbus issues So long as you wire directly to the battery, CANBUS won't be an issue. Where you can run into problems is in trying to control whether the Centech (or any other accessory) is energized by wiring up a relay in between it and the battery. It's a nice feature to have, but you must do it properly in order for it to work with CANBUS. Link to comment
ElJefe Posted July 6, 2007 Share Posted July 6, 2007 So long as you wire directly to the battery, CANBUS won't be an issue. Where you can run into problems is in trying to control whether the Centech (or any other accessory) is energized by wiring up a relay in between it and the battery. It's a nice feature to have, but you must do it properly in order for it to work with CANBUS. Define "properly"? Link to comment
paulcbrowne Posted July 6, 2007 Share Posted July 6, 2007 I used a Painless fuse block that has five fuses, three switched. I used the rear mechanic's plug to power the switching relay to turn on power that comes directly from the battery. Comes with a rubber cover. Got it from Martel Brothers. Used a similar setup on an LT and an F650. I had ordered a Centech panel from A&S and returned it after I saw it. The Blue Sea unit looks nice, but you'd need an external relay to switch power on to the fuse block. The Painless has the relay potted into the fuse block and not all fuses are switched. Link to comment
Don_Eilenberger Posted July 6, 2007 Share Posted July 6, 2007 Paul - perhaps a link to the "Painless" fuse panel? Link to comment
ElJefe Posted July 6, 2007 Share Posted July 6, 2007 I've used Painless Performance fuse blocks in Jeep projects for years. I was wondering if they might be too large to fit on a bike though, compared to the Centech one? Link to comment
Ken H. Posted July 6, 2007 Share Posted July 6, 2007 Painless Performance fuse blocks Yeaaah, seems a bit over the top for a bike. Link to comment
drzep Posted July 6, 2007 Share Posted July 6, 2007 Used two small machine screws to secure it under the passenger seat. Very secure and no leaks. Powered direct from the battery and triggered by the 12v lead of the factory nav harness. I used a 40A relay and a 35A inline fuse. Running PIAA 1100s, Autocom, Powerlet iPod charger, and rear aux socket. No problems with everything powered + heated vest. Front aux socket and GPS are straight to battery. Link to comment
Samzilla Posted July 8, 2007 Author Share Posted July 8, 2007 Thanks fellas. Your comments have really been helpful. Ken Link to comment
notacop Posted July 8, 2007 Share Posted July 8, 2007 I wanna know how the fish finder works? Link to comment
Jack90210 Posted July 8, 2008 Share Posted July 8, 2008 Used two small machine screws to secure it under the passenger seat. Very secure and no leaks. Old thread revival time ... Zep, you have a stock passenger seat? That setup doesn't rub against anything? It's hard for me to tell just how much clearance there is under the seat. Thanks. Link to comment
