mclayton Posted June 26, 2007 Share Posted June 26, 2007 just purchased new zumo 550. can I attach a BMW male plug to the end of the bike mount.I fried an IQUE doing the samt thing and hesitant to try with the ZUMO. Link to comment
Edgar Posted June 26, 2007 Share Posted June 26, 2007 You should be fine if you wire in an inline fuse of the proper wattage. Link to comment
mclayton Posted June 26, 2007 Author Share Posted June 26, 2007 thanks, I just needed some reassurance Link to comment
hopz Posted June 26, 2007 Share Posted June 26, 2007 Your bike mount cable has an in-line fuse already. If the supply is 12v. No problem. You can go to the zumo550forums.com for the best on line resource on the zumo Link to comment
UberXY Posted June 26, 2007 Share Posted June 26, 2007 just purchased new zumo 550. can I attach a BMW male plug to the end of the bike mount.I fried an IQUE doing the samt thing and hesitant to try with the ZUMO. Polarity. Link to comment
T__ Posted June 27, 2007 Share Posted June 27, 2007 just purchased new zumo 550. can I attach a BMW male plug to the end of the bike mount.I fried an IQUE doing the samt thing and hesitant to try with the ZUMO. Clyton, you should have a radio connector just under the L/H side of the fairing (just forward of the glove box) .. That connector should have both a 12V hot all the time terminal & a 12V terminal that is switched on & off with the ign switch.. That is an excellent place to wire in your Zumo.. Twisty Link to comment
mclayton Posted June 28, 2007 Author Share Posted June 28, 2007 Thanks everyone for the info. the radio plug sounds the way to go. Link to comment
