Nevets Posted June 15, 2007 Share Posted June 15, 2007 This morning I was running very low on fuel, and expected to see the low fuel warning lamp illuminate. I could have sworn I've seen it before, but am staring to wonder if the bulb is out, or whatever. Short of nearly running out of petrol, is there a way to make the lamp illuminate to check it? Inquiring minds wish to know... Link to comment
Willie Posted June 15, 2007 Share Posted June 15, 2007 I am assuming that you have run it low enough that there are no bars left on the RID, right? Mine USUALLY all gone before my light comes on. You could try draining off some more gas out of the tank and see if it lights then. If not, maybe bad bulb or something in the wiring??? I'm no expert though Link to comment
Ken H. Posted June 15, 2007 Share Posted June 15, 2007 Well it's not particularly easy, but if you disconnect the electrical connector going to the fuel tank and ground pin 4 (with the key on) a white wire, that should turn the lamp on. If it doesn't it could be the bulb itself; have to disassemble the dash to get to it to check it. Or there is a "electronic damper" in the circuit between the tank and the bulb that causes it to slowly come on and go off as the fuel level sinks. Rather than flash sporadically on/off. It could (but rarely) be the issue. OTOH if when you short pin 4 to ground the bulb does go on, give it a couple of seconds for the damper to come up, then the problem is likely within the tank. Link to comment
smiller Posted June 15, 2007 Share Posted June 15, 2007 You haven't by any chance had your fuel filter replaced recently have you? Link to comment
Nevets Posted June 15, 2007 Author Share Posted June 15, 2007 You haven't by any chance had your fuel filter replaced recently have you? No, I have not (yet) changed my fuel filter. I was also wondering if the light is should come on (momentarily) when the key is first switched on. If not, I like the pin 4 idea. Link to comment
Ken H. Posted June 15, 2007 Share Posted June 15, 2007 I was also wondering if the light is should come on (momentarily) when the key is first switched on.It does not. Link to comment
breyfogle Posted June 15, 2007 Share Posted June 15, 2007 ...It does not. Sure wish it did. Hard to tell if you're low on gas if the darn bulb is burned-out ! Link to comment
Rob L Posted June 15, 2007 Share Posted June 15, 2007 How much fuel do you need when you think that you are low? My light comes on when I need 6.1-6.2 gallons! Link to comment
