Will Knight Posted June 5, 2007 Share Posted June 5, 2007 While debugging a aux. lighting issue on my 04 R1150RT I pulled fuse #2 and turned on the switch. The fuse is fine, but after putting the fuse back the BRAKE FAILURE light stays on. It appears the the brake system is working okay. How can I reset this to get the light to go off? Link to comment
T__ Posted June 5, 2007 Share Posted June 5, 2007 While debugging a aux. lighting issue on my 04 R1150RT I pulled fuse #2 and turned on the switch. The fuse is fine, but after putting the fuse back the BRAKE FAILURE light stays on. It appears the the brake system is working okay. How can I reset this to get the light to go off? Will, try riding the bike a little ways then try turning the ign switch completely off,, then do a couple of restarts.. On my 02 it usually takes a short ride then few re-starts to make the light go out.. Twisty Link to comment
bmwmick Posted June 6, 2007 Share Posted June 6, 2007 While debugging a aux. lighting issue on my 04 R1150RT I pulled fuse #2 and turned on the switch. The fuse is fine, but after putting the fuse back the BRAKE FAILURE light stays on. It appears the the brake system is working okay. How can I reset this to get the light to go off? Check for a burned out brake or tail lamp. Mick Link to comment
Will Knight Posted June 6, 2007 Author Share Posted June 6, 2007 The problem cleared up after riding and restarting the bike. Thanks for the quick replys. Link to comment
