JiminPA Posted June 3, 2007 Share Posted June 3, 2007 Hi all. I just picked up my first BMW yesterday, 2004 R1150RT. I was riding today and put my windshield down and now it won't come back up. Has anyone had a similar experience or know of anything simple I can check without a trip to the dealership. The warranty should be good until september so I don't want to dig too deep looking for the probelm. The closest dealer is a couple of hours away and my schedule is going to make it hard to get in soon. Thanks for any help. Jim Link to comment
Rich06FJR1300 Posted June 3, 2007 Share Posted June 3, 2007 check your fuses first...i think its the 3rd fuse in from the left side or 5th one...been awhile since i owned one. Link to comment
jojo Posted June 3, 2007 Share Posted June 3, 2007 it's fuse #3 (15A) but if it was dead, your RID (rider Information display) would be blank. The Haynes manual wiring diagram mentions 1 relay for lowering and 1 for raising the windshield but i can't see these relays in the fusebox. anyone knows where they are? Link to comment
jfremder Posted June 3, 2007 Share Posted June 3, 2007 It's the relay, BTDT... Unfortunately, they're under the front fairing, so it's a bit of work to get there it's fuse #3 (15A) but if it was dead, your RID (rider Information display) would be blank. The Haynes manual wiring diagram mentions 1 relay for lowering and 1 for raising the windshield but i can't see these relays in the fusebox. anyone knows where they are? Link to comment
JiminPA Posted June 4, 2007 Author Share Posted June 4, 2007 Hi All, Thanks for the help. I am not sure what I did to fix the problem. I changed the fuse and it still did not work, so I put the original back in. I tried to make sure everything was plugged in completely. The shield still did not work. So I gave up and went for a ride. While riding I tried it again and the shield worked fine. I guess riding is the answer. Jim Link to comment
ninermatt Posted June 4, 2007 Share Posted June 4, 2007 I guess riding is the answer. Jim Isn't it always? Link to comment
Barrie C Posted June 4, 2007 Share Posted June 4, 2007 Similar thing happened to me once, didn't fail completely but the motor was making nasty noises and it sounded like it was about to fail. I sprayed some! WD40 around the mechanism & it's been fine ever since Link to comment
ogjimbob Posted June 4, 2007 Share Posted June 4, 2007 Hi don't know how closely the 1150 follows the 1100 design, but I have just yesterday done the whole "strip down and repair" deal on my bike windshield.On the 1100 (you may have to adapt to the 1150) this assumes you have done the basic stuff such as ,check fuses etc. 1)knock off mirrors 2)remove screen by taking out 4No screws 3)remove 12No screws from cockpit area so allowing you to remove cockpit facia (disconnecting switches etc as you go) 4)undo 4 No 10mm bolts holding instrument panel 5)ease panel forward and down 6) you should now be able to see in the front R/H side 2No grey relays these are the windshield motor relays 7) remove both of the relays and scrape (with a knife or screwdriver) the blades untill shiney 8)spray sockets with wD40 or equivalant and refit relays 9)try operation of motor there is a very good chance that it will now work as most problems are caused by poor connections due to corrosion, if not then you will need to get new relays. hope this helps ken Link to comment
Ken H. Posted June 4, 2007 Share Posted June 4, 2007 don't know how closely the 1150 follows the 1100 design, It's the same. Link to comment
EffBee Posted June 4, 2007 Share Posted June 4, 2007 It's the relay, BTDT... Unfortunately, they're under the front fairing, so it's a bit of work to get there it's fuse #3 (15A) but if it was dead, your RID (rider Information display) would be blank. The Haynes manual wiring diagram mentions 1 relay for lowering and 1 for raising the windshield but i can't see these relays in the fusebox. anyone knows where they are? Yup. Never seen a motor go bad, although I've seen one switch go bad. But 95% of the time it's the relay. No special tools needed. Just a 3mm T-handle and a large phillips, and a lot of patience. Link to comment
jfremder Posted June 6, 2007 Share Posted June 6, 2007 Not to be a bubble burster, by mine had the exact symptoms you descibe, working, not working, working, until finally it was stuck permanently down. I tried riding it over and over again to no avail Finally replaced the relay. Hi All, Thanks for the help. I am not sure what I did to fix the problem. I changed the fuse and it still did not work, so I put the original back in. I tried to make sure everything was plugged in completely. The shield still did not work. So I gave up and went for a ride. While riding I tried it again and the shield worked fine. I guess riding is the answer. Jim Link to comment
algover Posted June 8, 2007 Share Posted June 8, 2007 I had the same problem, but in the opposite direction. Intermittently, but with increasing regularity, the windshield would go up but not back down. A local dealer couldn't find the problem, but Paul Mihalka diagnosed it the moment I described it to him: "the down relay" (in my case). That was replaced and no further problems. Link to comment
