wrestleantares Posted June 2, 2007 Share Posted June 2, 2007 Well I went to ride today and did not get far. My bike made a slight (and I mean slight) rattle in upper RPM, cut off and died. The starter is not getting enough juice to restart the bike. Any thoughts of what to check - before I begin the tear down? Do you think it is just the battery and I should try that, or is the slight rattle indicative of something else. NOTE: I have had a little bit of problem with this battery before despite it being fairly new (out of warranty time though). Link to comment
hazmat Posted June 3, 2007 Share Posted June 3, 2007 You could have a bad alternator they are gear driven and do rattle with no load on them. Did you try jumping it or is it just dead in the water? A very good place to ask questions is the http://www.bmwlt.com/forums/cmps_index.php forum they have wizards there and probably tell you whats wrong in a short time. What year is it, some of the older ones when the voltege was low would weld the starter contacts togater. Good Luck! Link to comment
tallman Posted June 3, 2007 Share Posted June 3, 2007 Methinks he just needs a companion. Someone to keep his heart kickstarted. Good luck, hope for a quick and esy solution. Link to comment
