TracerBullet Posted June 1, 2007 Share Posted June 1, 2007 I have a little bit of weeping (I know probably normal and I am not worried) but that is not my question Should there be a zip tie on both ends of the boot? There is only a tie on the larger end. Before I zip tie the other end (there is an open space as it is not tight) I wanted to ask thanks Link to comment
T__ Posted June 1, 2007 Share Posted June 1, 2007 I have a little bit of weeping (I know probably normal and I am not worried) but that is not my question Should there be a zip tie on both ends of the boot? There is only a tie on the larger end. Before I zip tie the other end (there is an open space as it is not tight) I wanted to ask thanks Sal, my 02 1150RT has a zip tie on both ends of the boot.. Possibly BMW made a running change but the 02 uses one each end.. Twisty Link to comment
jojo Posted June 1, 2007 Share Posted June 1, 2007 my '04RT has one cable strap on both ends and that's the way it should be according to the part fiche. Link to comment
TracerBullet Posted June 1, 2007 Author Share Posted June 1, 2007 thanks all. My strap must have broke off off to get a new one Link to comment
jojo Posted June 1, 2007 Share Posted June 1, 2007 from MAX BMW: p/n 33172335139 cable strap (L=450) BUY 2 $1.90 Link to comment
Clive Liddell Posted June 2, 2007 Share Posted June 2, 2007 My R has two metal "hose clamp" style straps but the 2000 RT came with one metal and one "cable tie". The two are different lengths and I replaced my one cable tie with the metal clamp for better weep control Expect to pay (a LOT) more for the metal clamp though... Link to comment
flars Posted June 3, 2007 Share Posted June 3, 2007 I don't believe in paying the 'big bucks' for a o-fi-shul BMW part, so I used a cable tie. I couldn't find a real long one anywhere in my garage, so I just used two ties zipped together. I've done it twice in the last 30,000 miles, and it seems to work just fine. Link to comment
