majordad Posted May 30, 2007 Share Posted May 30, 2007 I am currently having my bike serviced because of the mishap I created changing the rear tire. I have having the 24k mile service done at the dealer minus the rear diff and trans fluid replacement, spark plug replacement and air filter replacement. I told the service manager not to do the valve clearance check and will defer this to the 36k mile service interval when I have the alternator belt changed. Any realistic harm in delaying this given the fact the valve clearance was fine at 14k miles (when 12k service interval performed)? the bike currently has 24xxx miles on it now. Link to comment
Boffin Posted May 30, 2007 Share Posted May 30, 2007 The check only takes a few minutes so any savings will be minimal - why bother not doing it? Andy Link to comment
majordad Posted May 30, 2007 Author Share Posted May 30, 2007 it's what I can afford and this dealership told me they charge by the hour and not a flat fee for interval service. I would be the one told it took 2 hours to check the valves, 2 hours to change the fuel filter, and 2 more hours to replace the brake and clutch fluids. At $70 an hour, the cost mount up. Link to comment
Boffin Posted May 30, 2007 Share Posted May 30, 2007 Two hours to check the valves? That is BS, you only need to remove the rocker covers (4 bolts) turn the engine to TDC, measure the gap, turn to the other TDC measure the gaps, refit the covers. 15 minutes max. Do not forget, they have the tupperware off to do the fuel filter already... I would contest their labour times. Andy Link to comment
Davis Posted May 30, 2007 Share Posted May 30, 2007 If you want, I'll be glad to help you check/adjust your valves. Send me a PM. Link to comment
majordad Posted May 31, 2007 Author Share Posted May 31, 2007 Two hours to check the valves? That is BS, you only need to remove the rocker covers (4 bolts) turn the engine to TDC, measure the gap, turn to the other TDC measure the gaps, refit the covers. 15 minutes max. Do not forget, they have the tupperware off to do the fuel filter already... I would contest their labour times. Andy I should have been more clearer. I meant I would be the one told that.....sort of like "things like that happening to only me". I generally try to acquire the total price of maintenance costs prior to committing to them. Link to comment
ncsonderman Posted June 3, 2007 Share Posted June 3, 2007 Are you having your bike serviced at Hammersley? I've only heard good things about their service and can personally attest to their ability to get the parts that I need in a quick and inexpensive (less expensive ) manner. Hope all turns out well. +1 on checking your own valves! Link to comment
Steve W. Posted June 3, 2007 Share Posted June 3, 2007 So with all the tasks you listed deleated from the service, what's left for the stealer to do? Why not just do it yourself? What was the mishap with the wheel? By the way bikes don't have "diffs", must have two driven wheels to need a "diff", (like a car). Cheers Steve Link to comment
T__ Posted June 3, 2007 Share Posted June 3, 2007 So with all the tasks you listed deleated from the service, what's left for the stealer to do? Why not just do it yourself? What was the mishap with the wheel? By the way bikes don't have "diffs", must have two driven wheels to need a "diff", (like a car). Cheers Steve Steve, he left the rear brake caliper off & managed to pop a caliper piston out.. Couldn’t get the rear brake re-bled himself so is having dealer bleed brakes.. As long as tank is removed for brake bleed might as well have filter replaced.. Twisty Link to comment
Steve W. Posted June 3, 2007 Share Posted June 3, 2007 Steve, he left the rear brake caliper off & managed to pop a caliper piston out.. Couldn’t get the rear brake re-bled himself so is having dealer bleed brakes.. As long as tank is removed for brake bleed might as well have filter replaced.. Twisty That sounds like a smart deal. The stealer can only charge for R&R tank once. May want to consider the remote filter option. Of course a dealer would poo poo that procedure. Cheers Steve Link to comment
