R1100RT Side Stand Question
allynr1100
allynr1100
If you grab the end of my side stand and wiggle it (perpendicular to the bike) it moves about 1/2 inch. Is this any big deal? Would replacing the bushing tighten it up any?
Mine wiggled. I tightened the screws.
But that was after we removed the entire sidestand to weld on a larger footprint!!!!! clap.gif
ShovelStrokeEd
I don't think there is a bushing, only a stripper bolt in a hole. You would have to remove the assembly and inspect. If the hole is worn oblong, replace the side stand, if the bolt is worn, replace the bolt.
Eckhard Grohe
There is a bushing and I wouldn't worry about 1/2" of movement. It's just a sidestand and not meant to be precise. The Germans are learning cost effective engineering at long last.
Just make sure the bolt is tight.
Now if only parts prices would be reasonable.
