dwightm Posted May 20, 2007 Share Posted May 20, 2007 Ok I went to install the rear shock and find that the BM702 Reservoir fitting from the shock body is bent at to large an angle and will need to be tweaked about 10 degrees. This is on a '02 K1200RS. I just love it when parts fit Can anyone recommend a Ohlins rebuilder in the Ohio area that can recharge/oil fill the shock after the fitting is persuaded back to angle where it will alow the rear right body panel to fit? Thanks Dwight-NEO Link to comment
