Wyn Posted May 18, 2007 Share Posted May 18, 2007 Looking for the best tankbag for Nubb. Is there a magnetic where the magnet is in front and rear? Most bags I see are side to side and of course won't work on plastic. Thanks in advance. ISYHTRAH Link to comment
Jerry Johnston Posted May 18, 2007 Share Posted May 18, 2007 Do you mean R1100 because all the airheads I've owned had metal tanks. I had a magnetic tank bag scratch the heck out of one of my airheads. I had set it down on a work bench and it picked up a piece of wire that I hadn't noticed until too late. Link to comment
Rob L Posted May 18, 2007 Share Posted May 18, 2007 I use Big Mak........doesn't touch the tank and hinges up to allow fuel replacement http://www.cyclegadgets.com/Products/BigMak/ Link to comment
Wyn Posted May 19, 2007 Author Share Posted May 19, 2007 So gimme a dopeslap! It's a miss print. I have an 98 R1100RT. Forgot the extra 1. May we start again? ISYHTRAH Link to comment
Rob L Posted May 19, 2007 Share Posted May 19, 2007 So gimme a dopeslap! It's a miss print. I have an 98 R1100RT. Forgot the extra 1. May we start again? ISYHTRAH OK, no problem! I use Big Mak........doesn't touch the tank and hinges up to allow fuel replacement http://www.cyclegadgets.com/Products/BigMak/ Link to comment
Davis Posted May 19, 2007 Share Posted May 19, 2007 Also look at SW Motech and Marsee Corona . They don't touch the paint, remove easily for gassing up, and don't leave as obtrusive a mount on your tank when the bag is removed as the Big Mak. The Big Mak is very nice, I have one and am pleased. I spent some time machining replacement mounting bolts to make it easier to remove the platen when not using the tank bag. While the flip up to fill is nice, if you install a BMR shelf or mount electronics in front of the dash, the bag will no longer stay flipped up, making fueling less convenient. If I were buying a bag today, I'd be looking at one of the other alternatives. Link to comment
