JGP Posted May 17, 2007 Share Posted May 17, 2007 Can the fuel gauge be adjusted? Mine when full reflects one bar short of full? jgp Link to comment
twilmotte Posted May 18, 2007 Share Posted May 18, 2007 Mine is same way, especially since bike is on side stand when I fill tank. I'm always more concerned about the gauge reading when the tank is almost empty rather than almost full. Link to comment
Morse Posted May 18, 2007 Share Posted May 18, 2007 Same here - it always shows one bar off the top when full .... must be designed that way for some reason. Link to comment
Laffo IBA#34115 Posted May 18, 2007 Share Posted May 18, 2007 There was a post a couple of months ago concerning this. The problem falls under TADT (they all do that) and is caused by corrosion at the fuel tank connections as well as at least three other connections until it gets to the indicator (RID). The problem gets worse over time and is corrected by cleaning the connection when the tupperware is off during your servicing chores. My understanding is that it does not affect the low fuel warning light but can't explain how it doesn't. I cleaned my contacts and now indicate full when I fill up and the top bar stays on for more than 1 mile so I'm good. Link to comment
Cycledude Posted May 18, 2007 Share Posted May 18, 2007 I read somewhere that in 04 the filler neck of the tank was changed. The filler neck was lowered. The result was less fuel being able to be put into the tank. They did not change the bend or make up of the float mechanism. Mine, when full, shows all bars. 10 miles down the road and I am back to one bar missing. I have never opened the tank to know see how the gauge mechanism works. However, I had Concours a few years back and I did "adjust" the mechanism to read low fuel later. I bent the float lever down slightly. If the BMW is a similar float and lever set up, I would guess you would just have to bend the float lever down a touch. This would move the senor higher getting your missing bar of fuel to show. Two different goals, same adjustment. Snowy. Link to comment
Scarecrow Posted May 20, 2007 Share Posted May 20, 2007 I read somewhere that in 04 the filler neck of the tank was changed. The filler neck was lowered. The result was less fuel being able to be put into the tank.Is it true that 04 1150RT owners can replace the fuel filler neck with one made for a 1100RT and get a bit more fuel in the tank? Is it easy to swap the 2 parts? Any downside? And how much extra fuel can you load that way? I've heard numbers ranging up to 1/2 gallon. If it's easy, and relatively cheap, I'd like to extend my riding range per tank a bit... TIA, Link to comment
beemer_me_up Posted May 20, 2007 Share Posted May 20, 2007 On my 04 1150RT the top light will light if I really fill it to the limit. Then it goes out after 12 to 15 miles. Also when the last bar is lit and the yellow light comes on, I am good for at least another 50 miles. If all highway at 70 - 80 mph range I have gone just over 300 miles on a tank of mid-grade gas. Link to comment
John in NC Posted May 21, 2007 Share Posted May 21, 2007 Mine had the same problem. I sprayed some contact cleaner on the connector on the right side of the fuel tank then applied some dielectric grease. Problem solved. Link to comment
jbr7t Posted May 22, 2007 Share Posted May 22, 2007 On my 04 1150RT the top light will light if I really fill it to the limit. Then it goes out after 12 to 15 miles. Also when the last bar is lit and the yellow light comes on, I am good for at least another 50 miles. If all highway at 70 - 80 mph range I have gone just over 300 miles on a tank of mid-grade gas. I got about 250 miles once, ALL slab at about 75 MPH. typical riding i get a little over 200 miles...but I haven't "pushed" the low fuel light. maybe i will try. Link to comment
