CraCol Posted May 17, 2007 Share Posted May 17, 2007 Has anyone tried or been able to remove the side stand from an R1200RT? There is a bushing in from the bottom that defies removal, and the CD manual is no help at all.. Thanks, TinMan. Link to comment
TEWKS Posted May 17, 2007 Share Posted May 17, 2007 Won't the bike fall over without it? Pat Link to comment
CraCol Posted May 18, 2007 Author Share Posted May 18, 2007 Won't the bike fall over without it? Pat Not if you remember use the center stand...;-) I need to get it off to shorten it. There is a bushing holding it in that doesn't have an apparent way to remove it, other then ripping it out and ruining it.. TinMan. Link to comment
TEWKS Posted May 18, 2007 Share Posted May 18, 2007 I didn't try it, but after removing the T50 bolt,spring & wires for the cut out switch, you may have to pull it forward or backwards instead of down. Pat Link to comment
CraCol Posted May 18, 2007 Author Share Posted May 18, 2007 I didn't try it, but after removing the T50 bolt,spring & wires for the cut out switch, you may have to pull it forward or backwards instead of down.Pat Tried that.. The busing (which instales from the back or bottom side) is pressed in and there isn't anything to get a bite on to get it out.. Link to comment
