Bill_R Posted May 16, 2007 Share Posted May 16, 2007 I have lubricant leaking from the rear boot (bike @ 20k miles). What am I in for??? Thanks. Link to comment
Mike T Posted May 16, 2007 Share Posted May 16, 2007 Bill, is it leaking from the final drive or the transmission? Usually the final drive will leak about a tablespoon of fluid into the boot area which is "normal" and nothing to worry about. You may want to check your fluid level in the final drive. If you are getting alot of leaking it needs to be dealt with. Not sure if it is just a seal or if the rear drive bearing has developed play which is causing the leak. Link to comment
Rob L Posted May 16, 2007 Share Posted May 16, 2007 Most likely leaking past the seal at the final drive. Check the level of oil in the rear drive, it should be at the BOTTOM of the threads in the filler hole. You can also remove the large clamp from the boot and clean the inside of the boot. Recheck at each oil change to monitor how much is leaking. A teaspoon is not excessive. Link to comment
Bill_R Posted May 18, 2007 Author Share Posted May 18, 2007 Thanks for the thoughts. Not sure if it's coming from the trans. or final drive (haven't had time to remove the boot yet). Just suspect that when something begins to drip, that didn't for 4 years, that it probably isn't good. Link to comment
jojo Posted May 18, 2007 Share Posted May 18, 2007 Just suspect that when something begins to drip, that didn't for 4 years, that it probably isn't good. If it can cheer you up, mine started leaking at 20k. I still don't know whether it's the FD or the trans but I check both levels between services and I never had to top them up. There was actually no noticeable drop of oil level. The bike has now 32k on the clock and still leaking Link to comment
smiller Posted May 18, 2007 Share Posted May 18, 2007 As others have said, a small amount of oil (a few teaspoons or so every couple thousand miles) in the boot (either from the final drive input or transmission output) is nothing to worry about and probably not worth the dollars to fix. Just check the oil levels once in a while (even though at that rate it will take a long time for there to be any noticeable difference, they'll probably be no need to add any between the recommended 12k mile oil changes.) Link to comment
flars Posted May 19, 2007 Share Posted May 19, 2007 If I were you, I would be very careful with this. I found some oil leaking from the FD boot at around 40000 miles, and now I have had to worry about it for the last 75000 miles. Yes, it now has 115000 miles on it. Nothing has happened yet... Link to comment
Larry Posted May 19, 2007 Share Posted May 19, 2007 Is a special tool needed to remove the seal? If so can you make it or use another tool? Link to comment
Ken H. Posted May 19, 2007 Share Posted May 19, 2007 Is a special tool needed to remove the seal? If so can you make it or use another tool? Depends on which one it is. Usually it's the final drive input seal and they are conventional to replace. Link to comment
