KingBee Posted May 15, 2007 Share Posted May 15, 2007 Hi All! I'm a new guy here, with a problem. I have a 96 R1100rt with 65000 miles on it. I believe the ABS main relay is stuck . I get a whine from the ABS whenever the battery is connected. I've got the tupperware off, and the gas tank, but I'm reluctant to go deeper without some advice. Can I replace this relay at home? Can it be disconnected so I can ride until I find the parts? Thanks! Jim Link to comment
KingBee Posted May 17, 2007 Author Share Posted May 17, 2007 Well, after taking apart way more than I needed to, I found the rely under a plastic cover on the ABS unit. Looks like it will be simple to replace, now that I've found it. Link to comment
Bprimm Posted May 17, 2007 Share Posted May 17, 2007 Well, after taking apart way more than I needed to, I found the rely under a plastic cover on the ABS unit. Looks like it will be simple to replace, now that I've found it. Sorry I missed your question but part #61362306526, abs motor relay, costs about $95 new so maybe the "Beemerboneyard" site can help you out with one from a pump that failed. Click below...... used and new parts Link to comment
John Dickens Posted May 17, 2007 Share Posted May 17, 2007 This is where it lives:- It's behind the sliding cover (9). Link to comment
KingBee Posted May 17, 2007 Author Share Posted May 17, 2007 Thanks, gentlemen. I've ordered a new relay from MAX BMW. $95 seems steep, but I don't want to have to fool around with this again. Link to comment
