bluepassat Posted May 12, 2007 Share Posted May 12, 2007 Hi A friend of mine has the K1200LT and has found the left hand side front and rear speakers don’t work? (Right hand is ok) He has checked the balance and fader controls all ok but still no sound My question is how easy is it to check the connections at the radio itself (also where is it) or it their a multi plug come loose? Any advice or suggestions welcome Kind regards Link to comment
10ovr Posted May 13, 2007 Share Posted May 13, 2007 My 03 LT did that,,It was a bad radio,You have to take off all the body to get the top cover over the tank off,Radio is bolted to top cover, Link to comment
tbarstow Posted May 13, 2007 Share Posted May 13, 2007 Tell your friend to check out bmwk1200lt.com for a more in depth description of how to get to the radio connections and which connectors to check. In the Hall of Wisdom, there is a diagram of the radio pin connections. Link to comment
