topdal46 Posted May 11, 2007 Share Posted May 11, 2007 I have a Garmin 2720 GPS, is there a way to get a alititude readout on it? I noticed that if I save a current location as a favorite it will show altitude, but is it possible without going through that step? Link to comment
Couchrocket Posted May 11, 2007 Share Posted May 11, 2007 Read the manual. You can customize the display in the "map screen" for both "while navigating" and when just driving w/o a route "engaged." In both of those customization menus, there is a plethora of choices for what you can have displayed. ETA, Speed, Dist. to next, alt., etc. Easy to do, once you've messed with it a bit. If you don't have a manual for some reason, you can download from Garmin here. Link to comment
topdal46 Posted May 13, 2007 Author Share Posted May 13, 2007 Thanks guys, I was just up in Santa Fe , NM, now that's a high place, 6911ft elevation where I was visiting a friend of mine. I thought it would be nice to see the elevation as I was riding, I'll go check it out, I checked out the manual, but didnt' find a whole lot there. Link to comment
topdal46 Posted May 13, 2007 Author Share Posted May 13, 2007 I've looked all over the settings, map, and I can't find where you change the screen . Link to comment
ShovelStrokeEd Posted May 13, 2007 Share Posted May 13, 2007 I have a 2730 but I think they are similar. Menu/settings/map/map data fields/wide or thin and then choose your preference. I still haven't figured out how to configure it like I want but I'm getting closer. I much preferred the system on my GPS V where I could select the number of fields and what I wanted in each. Whoever wrote the Garmin manuals is an idiot. Link to comment
topdal46 Posted May 13, 2007 Author Share Posted May 13, 2007 that's getting closer, let me try it Thanks... Link to comment
NoHeat Posted May 15, 2007 Share Posted May 15, 2007 I have a 2730 but I think they are similar. Menu/settings/map/map data fields/wide or thin and then choose your preference. That is helpful, Ed. Thanks. Whoever wrote the Garmin manuals is an idiot. Or lazy. Or both. The manual for the 2720/2730 merely points out what is already obvious while ignoring everything that really requires instructions. For example, it's completely un-obvious that you should click a menu item called "thin" in order to find where to add alitutude to a display -- the manual doesn't help you at all in discovering this, but it points out the painfully obvious stuff like click 'faster' if you want to a faster route but 'shorter' if you want a shorter route. Link to comment
topdal46 Posted May 15, 2007 Author Share Posted May 15, 2007 ShovelStroke ED,, I tried your suggestion, and it work , too bad Garmin doesn't have end users in mind when they write their manuals. thank you Link to comment
