RoSPA_man Posted April 15, 2007 Share Posted April 15, 2007 Hi Anyone know whether the BMW rectangular badge on the pannier lids is stuck on or screwed on- hard to tell with the double skin. If screwed on, how do you gain access? If stuck on, can it be removed in such a way as to be refitted without being damaged by removing it etc? Ditto question for the BMW round badge on the top box. Thanks Link to comment
John in VA Posted April 15, 2007 Share Posted April 15, 2007 It's stuck on with very strong double-sided tape. Use some kind of stiff plastic scraper tool wedged under the edge and lift slowly. A credit card might work, but even its edge might mar the paint. Link to comment
John in VA Posted April 15, 2007 Share Posted April 15, 2007 Also, count on buying a new reflector because it's backed up by flimsy white cardboard that will tear when you scrape the double-sided tape residue off the pannier in bits and pieces. Link to comment
twolfy Posted April 16, 2007 Share Posted April 16, 2007 You could run a piece of fishing line under it. Just saw back and forth under it and it will come off. You could also heat it up with a hair dryer or heat gun, carefully< just enough to soften the adhesive and lift it off. Tom Link to comment
