Redbrick Posted April 11, 2007 Share Posted April 11, 2007 Embarassed , but here goes......Where is it on the RT 1200? ....Take off one of the fairings and there it is??? The following Graemlin is OK to use with responses Phil........Redbrick Link to comment
Limecreek Posted April 11, 2007 Share Posted April 11, 2007 Rt. side. Remove the both fairings--find the snorkle, trace it back to the box. See the plastic clips? Press them down and slide the base of the snorkle toward you, oh and remove the the snorkle from it's rubber gromet--do that first. Link to comment
Redbrick Posted April 11, 2007 Author Share Posted April 11, 2007 Thanks Gregory... Figgered it was under there somewhere and hopefully not under the tank.... Phil.......Redbrick Link to comment
ScottT Posted April 11, 2007 Share Posted April 11, 2007 Not under the tank... see my attachment. Well, actually it is sort of under the tank. You don't have to remove the tank though. Much easier dealing with the air filter on my hexhead than it was with my oilheads. I used to have so much trouble getting the filter back in with the oilheads. Link to comment
Redbrick Posted April 11, 2007 Author Share Posted April 11, 2007 Not under the tank... see my attachment. Well, actually it is sort of under the tank. You don't have to remove the tank though. Much easier dealing with the air filter on my hexhead than it was with my oilheads. I used to have so much trouble getting the filter back in with the oilheads. Thanks for the diagram Scott....No problem now...... Phil.......Redbrick Link to comment
