JRoper Posted April 8, 2007 Share Posted April 8, 2007 I am still having a problem with engine whine coming through to the speakers. This buzzing is heard even if all periferals are disconnected. The box is located under the seat, power is connected to the switched fuse box and ground is connected directly to the battery ground. I have isolated cables on all items connected, like GPS, iPod, & cell phone. I'm getting a bit discouraged after spending so much money on a system that doesn't work right. Link to comment
Eschelon1 Posted April 8, 2007 Share Posted April 8, 2007 May be you're picking up interference from the spark plug wires? Link to comment
UberXY Posted April 8, 2007 Share Posted April 8, 2007 Buy a ground loop isolator for the power line. I got one at Crutchfields for about $15 - I am sure that Radio Shack sells them too. The Autocom one is $$$$$$$. I had the same problem, as many people have, and the isolator fixed it. For the prices Autocom charges, one ought to be built in. Link to comment
markgoodrich Posted April 8, 2007 Share Posted April 8, 2007 Don't bother with Radio Shack. The only one they carry has RCA plugs, you need 3.5mm. Link to comment
JRoper Posted April 9, 2007 Author Share Posted April 9, 2007 I finally figured it out. I had bought an isolated cord for my iPod to solve the engine noise problem. After installation, the noise problem got worse. I just now found out that the box in the cord containing the isolation electronics was too close to the battery and probably some other high current lines. I moved the box 6" away and problem solved, finally! Thanks for your help. Link to comment
