itroop Posted April 8, 2007 Share Posted April 8, 2007 I just checked the post for the maintenance data at the top of this section. There was so much useful information posted. Either I missed the part for the 1150RT's replacement oil filter or it wsan't posted. I'm sure I just overlooked it. Can someone please give me the brands and part number for an aftermarket oil filter for an 02 R1150RT. Thanks, Mark Link to comment
Boffin Posted April 8, 2007 Share Posted April 8, 2007 I just checked the post for the maintenance data at the top of this section. There was so much useful information posted. Either I missed the part for the 1150RT's replacement oil filter or it wsan't posted. I'm sure I just overlooked it. Can someone please give me the brands and part number for an aftermarket oil filter for an 02 R1150RT. Thanks, Mark ALl of the oilhead motors use the same filter, so the list as given will work for you. Here it si: Oil filters: FRAM is the correct FRAM but hard to find at WallyWorld. PH6063 FRAM is readily available and works PH3614 AC DELCO PF-53 NAPA 1348 Mobil-1 M1-102 BMW 11.42-1 460 843 or 845 Mahle/knecht/microstar/tecafiltre (original part) OC91 Champion (of motorcycle range) C301 Purflux LS188B Tech9 (France only, made by Mahle in fact) n°16 Hiflofiltro (from Thailand) HF-163 Mann-Hummel MW712 Detlev Louis (Germany) 10050195 Toyota 08922-02004 or 90915-YZZB9 Perf-form (on www.perf-form.com) BMW-1 UFI makes one too (italian) Donit (www-motobins.co.uk) 43 10 133 For After May, '97, 1100RT Purolator P/N11421460845 AMSOIL SMF122 Bosch 3330 WalMart ST3614 Purolator L00241 AC PF53 Andy Link to comment
itroop Posted April 8, 2007 Author Share Posted April 8, 2007 Thank you for clearing that up for me. Mark Link to comment
Stan Walker Posted April 8, 2007 Share Posted April 8, 2007 Oil filters: FRAM is the correct FRAM but hard to find at WallyWorld. PH6063 FRAM is readily available and works PH3614 AC DELCO PF-53 NAPA 1348 Mobil-1 M1-102 BMW 11.42-1 460 843 or 845 Mahle/knecht/microstar/tecafiltre (original part) OC91 Champion (of motorcycle range) C301 Purflux LS188B Tech9 (France only, made by Mahle in fact) n°16 Hiflofiltro (from Thailand) HF-163 Mann-Hummel MW712 Detlev Louis (Germany) 10050195 Toyota 08922-02004 or 90915-YZZB9 Perf-form (on www.perf-form.com) BMW-1 UFI makes one too (italian) Donit (www-motobins.co.uk) 43 10 133 For After May, '97, 1100RT Purolator P/N11421460845 AMSOIL SMF122 Bosch 3330 WalMart ST3614 Purolator L00241 AC PF53 But which of these is better than the BMW filter? And which is sub-par? In any given 6000 mile service interval I use about $430 dollars worth of gas, another $150 of wear on my tires, probably $150 for insurance, plus oil and other low cost items including one oil filter. I just can't get very excited about saving a few dollors on after-market oil filters, some of which are of such low quality I wouldn't put them on my car, let alone one of my bike. Stan Link to comment
ericfoerster Posted April 8, 2007 Share Posted April 8, 2007 Some good reading here: http://motorcycleinfo.calsci.com/Filters.html#OilFilters More good stuff here: http://motorcycleinfo.calsci.com/FilterStudy.html Stan is right, why take chance? I do use the Mobil 1 filter only due to the testing it has been through. Link to comment
ninermatt Posted April 9, 2007 Share Posted April 9, 2007 Some good reading here: http://motorcycleinfo.calsci.com/Filters.html#OilFilters More good stuff here: http://motorcycleinfo.calsci.com/FilterStudy.html Stan is right, why take chance? I do use the Mobil 1 filter only due to the testing it has been through. +1 Link to comment
itroop Posted April 9, 2007 Author Share Posted April 9, 2007 Thanks for the resposes. With that said, is there an oil that I can get a an automotive shop that will work in the bike? Oil changes at 3k miles. I figure if I change at 3k miles, just about any motorcycle oil will work. Am I off base or in the ballpark? Link to comment
Ken H. Posted April 9, 2007 Share Posted April 9, 2007 Thanks for the resposes. With that said, is there an oil that I can get a an automotive shop that will work in the bike? Oil changes at 3k miles. I figure if I change at 3k miles, just about any motorcycle oil will work. Am I off base or in the ballpark? Do a search on "oil" here and you will find several 100 post on this subject with just about as many opinions! But if you want my opinion, 3K is ridiculously too often to change your oil, and any major brand will do just fine. Link to comment
